delica vibration issue
kiwi daz
Vehicle: mitsi delica
Post by kiwi daz »
hi all
just bought a delica van, has a lovely vibration which starts around 80km/h and gets unbearable after 95km/h. I have 3 things which I think it may be
balance shaft belt
driveline, driveshaft out of balance?
wheels tyres-has got 235 tyres on rims and I noted that factory are 215's? rims could be bent?
any thoughts?
cheers
DARRIN
Re: delica vibration issue
Start with your tires and rims
Have them balanced
If that doesn't work, then check your driveshaft ujoints
kiwi daz
Post by kiwi daz »
jfarsang wrote:Start with your tires and rims
Have them balanced
it isnt coming through the steering wheel - its through the floor under your feet. So i doubt its the rims etc, well on front wheels anyway.
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
Did you change tire recently or off road?
Off road it is easy to knock of wheel weights or more likely you pack a little mud in 1 spot on 1 rim. (also make sure to wash wheels before buying tires most tire shops balance them up all muddy--bad idea)
Next
Check the u-joints on the back (Foward to reverse the sometimes clunk) get under there and give the shaft a shake?
You didn't specify whether you have an L300 or an L400. Makes a difference.
If it's an L300, you will feel vibrations through unbalanced tires and worn driveline ujoints through the floor. Not always at the steering wheel.
Also can be your transmission mounts.
The driveshafts are so short on the L300's that a vibration can come from anywhere. Put it up on a hoist and feel/look at those points.
kiwi daz
Post by kiwi daz »
jfarsang wrote:You didn't specify whether you have an L300 or an L400. Makes a difference.
well its a jap import, its a 1991 delica 4wd 4d56 turbo. so the front UJ's can cause vibration?
thedjjack
Post by thedjjack »
Front u-joints only if they are turning (hubs locked)
What about the tranny (or engine) mounts?
By the way, what are you driving and where are you located, roughly?
Welcome to Delica Canada :M
kiwi daz
Post by kiwi daz »
FalcoColumbarius wrote:What about the tranny (or engine) mounts?
will take a look when weather is a bit better, definitely will have a look at all things discussed. Im In New Zealand :o
We have at least two other members in NZ, one in Auckland, one in Taranaki. You know, if you guys start getting together and get more of you ~ we can make a NZ events page so you can plan meets.
kiwi daz
Post by kiwi daz »
FalcoColumbarius wrote:We have at least two other members in NZ, one in Auckland, one in Taranaki. You know, if you guys start getting together and get more of you ~ we can make a NZ events page so you can plan meets.
well Im kinda halfway in between in Hamilton, I bought mine for kayaking
You guys should hook up, I'm serious. Nothing like local help and shared wisdom.
Pommie in NZ
Falco.[/color]
