Clutch Release Bearing
Firesong
Post by Firesong »
I am looking for a part number for a release bearing.
Wondering if I can simply walk into Bearing and Transmission to
pick up the bearing.
Any numbers or help
FS
kidwrecked
Vehicle: 92 Jade High Roof
Re: Clutch Release Bearing
Post by kidwrecked »
I don't have a part # but the block, flywheel, clutch, etc. are the same part#s as a 1985 Dodge Ram D50 pickup. The engine # from the Dodge is a 4D55 and ours is a 4D56, same block, etc but different head, turbo, etc.
I researched it out for my L300.
Hope this helps.
Firesong
Post by Firesong »
It isn't
The clutch is, but the release bearing isn't.
I know this for fact.
Otherwise I wouldn't have this problem.
When we did the clutch the bearing didn't fit.
So....
I think I may have found some part numbers that might.
FS
mdrive
Post by mdrive »
DELICA CLUTCH BEARING MR195689
Firesong
Post by Firesong »
Quick question for those in the know.
Is it a good idea to also change the clutch pilot
bearing or is that something different altogether?
Already going to order a clutch release bearing.
James
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
Yes change the pilot Bearing it is in the end of the crank shaft and holds the end of the transmission input shaft up. Should be changed with the clutch.
