wiring diagrams
Breanne
Vehicle: delica
wiring diagrams
Post by Breanne »
Hi my delica L300 is having an issue starting in park.... if i put it in neutral it has no issues ... any clue?
also if anyone has a wiring diagram they could post that could help me out a lot
cheers bre
Re: wiring diagrams
Go to the forum index (click on "forum" up in the top left of your screen), then go to: Delica Canada Technical/FAQ and Downloads/L300 Delica Downloads/L300 Electrical Wiring Diagrams & Manual.
Then click on Engine Electrical Manual.
The forum index can be quite the useful tool... smiles.
loki
Re: wiring diagrams
Post by loki »
there are many posts in the L300 tech section of people having this issue, usually turns out to be the safety switch in the shifter, you can get the part from Amazing Auto Imports, CCAutos, or Rocky Mountain imports.
TardisDeli
Re: wiring diagrams
Post by TardisDeli »
Agree with Loki, sounds like the neutral safety switch died. Christine.
Christine
Breanne
Vehicle: delica
Re: wiring diagrams
Post by Breanne »
i found the issue it was to do with the gears... when i took off the cover from the gears there was an adjustable rod that when extended engages the parking gear... who knew???i guess it had vibrated loose
