Gauge pod
Temporary tool loans or swaps
deli1733
Vehicle: 1991 L-300 94 Pajero LWB
Gauge pod
Post by deli1733 »
i have a triple gauge pod but i need a double gauge pod if anybody wants to trade or knows where i could get one.
TardisDeli
Re: Gauge pod
Post by TardisDeli »
Just to say your offer should be popular, as the triple is hard to get. Cheers, Christine.
Jsq
Vehicle: 91 L300 High Top
Re: Gauge pod
Post by Jsq »
I'll trade...the triple has cabin/outside temps?
deli1733
Re: Gauge pod
Post by deli1733 »
yes it does
Jsq
Re: Gauge pod
Post by Jsq »
Do the double and triple guage pods use the same dash mount bracket/fastener hole spacing?
deli1733
Re: Gauge pod
Post by deli1733 »
i ddint notice that you had a 91 maybe call an import shop and find out im not sure
Re: Gauge pod
Post by Green1 »
Jsq wrote:Do the double and triple guage pods use the same dash mount bracket/fastener hole spacing?
No they do not, the temperature probes also require extra wiring (the dual pod has only power run to it, whereas the triple aslo has temperature inputs)
It's a do-able mod, but it's not simply plug and play.
Jsq
Re: Gauge pod
Post by Jsq »
Guess I'll stick with my double. Would like the exterior temp feature for winter but haven't got time to wire up my own system. Still looking for a decent electronics supplier. Till then...
Re: Gauge pod
Post by Green1 »
Jsq wrote:Guess I'll stick with my double. Would like the exterior temp feature for winter but haven't got time to wire up my own system. Still looking for a decent electronics supplier. Till then...
thermometers are dirt cheap at most auto parts places, I had one that I had stuck immediately under the dual gauge pod, I mounted the sensor to the back of the front license plate bracket. was really quick and easy to install. Doesn't look as "stock" as the three gauge pod, but it's much quicker and easier, and likely cheaper.
You can see it in this picture from my cross-canada trip 2 years ago
Return to “Tool Swaps, Share, Trade”
