Some of these numbers may not be applicable but some of the info here should be ok. Most of them have the genuine Mitsubishi part numbers. Any part that starts with a "M" is probably the gen part number. We have a very comprehensive list of L300 part numbers if anyone is interested..Just let me know and I will copy/paste them here or wherever you want them..
WARNING.....THE BOTTOM SECTION IS V6 PARTS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Cheers..
L400 - Common Parts and Diesel Variant Parts
Filters:
Fuel filter
FC1001
FF5160
Valvoline VF30
Z262/Z304 (RYCO) ($35)
Mits MB220900
Donaldson P550390
Mitsubishi Diamond Spectrum M*DS000298
Oil Filter
Donaldson P502008
Ryco WZ372 / Z372 ($35)
Purolater L45262 ($17)
Nippon Max MO-513
Mitsubishi Diamond Spectrum M*DS215002 ($28).
ME215002
ME088532
ME013343
Fleetguard LF3830
Valvoline V055
Air Filter
Uni-filter ULT290S
Finer filter 333004 / FLT 290S
A1312
MR204842
K&N E-2877
Oils/Fluids:
Engine: 8 litres, 15W/40 - Caltex CXJ recommended
Auto transmission fluid (ATF): 4 litres, Dexron III or Penrite ATF MHP (is semi synthetic and designed for Mitsubishi transmissions where MM SP, MM SP2, MM SP3 fluids are specified)
Transfer case: 2 litres, 75W80
Sump Plug
MD951858
Air-con System:
Compressor
MB946629
Model MSC130CV
Part No. AKC201A601
Air-con Compressor without the clutch assembly.
MR206800
Clutch
AKC272C606
Receiver-Dryer
RD7037
Belts:
Harmonic Balancer, Alternator to Waterpump
2 x MH014051
2 x Bosch 11A0980
Harmonic Balancer to Airconditioner Belt
Series 1
1 x MR360148
1 x Bosch 13A0940
Series 2
Bosch part# is 4PK930 or in a pinch
4PK925 will fit although slightly smaller
ENGINE
Glow Plugs
ME 201638/ ME 200970
HKT No. CP-05
Bosch GPF119
Series 2 Glow Plugs.
MMC part number ME203754
Glow Plug Control Relay
MD337888
Glow Plug Connecting Plate / Bus Bar
ME202443
Radiator
MR126103
Timing Chain
ENDUROTEC TCDR98LE ,fits Toyota and Porsche
Thermostat
Dayco part#250DT57E $33.00
Radiator Hoses
Top MB957100
Bottom MB126111 (VT V6 Commodore also fits). also may be known as MR126111
After Market Australian made By McKays available from Auto-Pro
Top Hose CH 3096 Approx. $16-17 (made for and Labeled for the Triton 2.8DT.)
Plastic expansion tank / Header Tank
MB924891
Turbo
Mitsu P/N ME201677
3rd party suppliers TF035 49135-03101 (stamped in the turbo housing)
Alternator
ME200695
A3T09199
VMN 10901101
New-Era 45-77571
MXA258
My Auto Electrician was unable to get me a MXA258 as listed in this thread at short notice. Although the supplier said they had one in Perth they didnt.
He found a Hyundai unit that bolts in with just one simple mod.
All that is needed is the bush in the mount leg needs removing and the other leg needs the hole drilled out to match the original mounting bolt.
That done and it slips straight in and works a treat. Modification and instalation no more than 10 minutes.
The Althernator is a
BAXTERS A-1432Cost $290.00 aust
Regulator (Alternator)
A866X27572
Rectifier (Alternator)
A866X47070
Ingram 821315
EXTRA ALTERNATOR PART NUMBERS:
4M40T 2.8 diesel, built before 3rd May 1997 are fitted with a 90A unit.
ME201837 (original part no) or replacement ME202755 Alternator Assembly 12V 90A.
ME701353 Rectifier, Alternator. (The diode pack of 9 diodes, 6 for power and 3 for control)
ME701363 Regulator, Alternator. (The electronic module that smoothes the rectified voltage from the diodes and limits it to 13.8V DC)
ME701349 Brush Kit, Alternator. (The carbon brush pair that wear down with use)
ME701578 Stator, Alternator. (The outer ring around the alternator with the heavy duty insulated wiring that carries the 90A)
4M40T 2.8 diesel, built after 2nd June 1997 are fitted with a 120A unit.
ME202232 (original part no) or replacement ME202756 Alternator assy 12V 120A.
ME701716 Rectifier, Alternator. (The diode pack of 9 diodes that rectifies the 3 phase alternator AC to DC)
ME701714 Stator, Alternator. (The outer ring around the alternator with the heavy duty insulated wiring that carries the 120A)
Starter Motor
ME200206 12volt
Gasket O/Drain Plug
MD050317
Muffler Exh Rear Section Inc Box
MB957431
Small Egr Base Gasket (Exhaust Side)
MR161679
12 X 40 Bolts Exhaust Fitting
MF241313
Rocker Cover
Rocker gasket ME200403
cover seals two of ME011282
camshaft ends two of ...ME200269...ME200270
Head Bolt Washer (4M40 Head)
MD020233
FUEL PUMP (Check To Confirm Individual Types)
ME201998 (for example 104741-3420)
Injectors
105007-1350 (based on Fuel Pump #104741-3420)
Harmonic Balance Pulley 4M40T
ME 202492
GENERAL
Front Shockers
KYB554103 / KE08
MR112096
MR353425 (ECS Fitted)
Bilstein F4-B46-2109-H0
Trackright Gas shocks 9151
Rear Shockers
KYB553211 / KE16
MR1152385
MR267538 (ECS Fitted)
Bilstein F4-B46-2111-H0
CV Joint
left side - CV Joint Australia in Auburn 0297437788. Protex PSA 412A (25 tooth inner spline )
( 25 tooth for 7.5 inch diffs , 28 tooth for 8 inch diffs )
Bump Stop
MB430156
Front Brake Pads
NS177H FF
Bendix DB1223/4WD ($59 at Super Cheap)
Mitsubishi MR389546
Piston Front Wheel (2 Per Side)
MB857837
Caliper Kits / Seals
PBR kit no. K2910S (Front)
MB857840
Rear Kits - KX3926S , available from Penrith Brake and Clutch - 02 4721 4893 $24 per side
Front Disc Wheel Holder
MB624908
Front Wheel Bearings
INNER E32010JA1 Bearing Industries 02 9681 2100 $30
OUTER LM102949/10 CBC. $20
or
Outer LM102949 $21.60 in Townsville at Associated Bearings 07 47793866.
Inner NP 626468 $34.50
Rear Brake Pads
Bendix DB1231/4WD
Rear Coil Springs
Pedders coil spring 7475 (L&R)
Ironman rear springs - MITS025B
Rear swaybar/ torsionbar Bushes
MB338595
Rear Anti Roll Bar Bushes
MR267684
Front Lower Sus. Bushes
MR112710
and MR112711
for aftermarket Nolathane bushes you need - 45513/RR7350 pkg of 2 and 45512/RR3440 pkg of 2
Front Torsion Bars
Ironman torsion bars - MITS031
Front Stabilizer Bar Links
MR267874 (City Mitsubishi Bris. Normal Price $136.65. Club members $106.25 per side - thanks to Jasper)
Control Arm Ball Joints
Upper (L/R) MR241623
Upper (L/R) BJ275
Lower (L) MR162697
Lower (R) MR162678
Gearbox extension housing Oilseal
MB 919210
Steering Rack Boots
Repco RRB082
MR151976
Inner CV boots
Mitsu part# DS000230
Kelpro part# CIB-503 ($25 from Repco/Supercheap etc).
Tie rod ends
Pedders TE 715R
Rack ends
MR151971 / MR151970
Koyo Seiko 4909138
64.M032
Battery Trays
Single MR105671
Dual MR105741
rubber seat under batteries MR158250
Window Hasp Nut (aka Rear Window Nut)
MB882036 ($11.60 each.)
MB683097 6x10mm and were $2.23!! each. (or you can probably get these at a hardware shop much cheaper)
Fixed Glass in Sliding Door
MR764192
Front Seat Belts
Klippan, SOB1010 or Mitsu 75725L (left side) and 75725R (right side)
Mitsubishi DIN pocket (dash)
MB877180
Blanking plate for where cupholders go
MR720531
Bulb For Compass
MR175492
Bulb Instrument Panel (Warning Lights)
MR167724
MR167725 (shorter bulb for L,2,D,N,R,P)
Bulb Dash Illumination
MR167722
Card Holder (fits in dashboard blanks)
MR590037
Coin Holder (fits in dashboard blanks)
MB562250
Light Lens For Sliding Door Footwell Lamp
MB877848
Centre Console (Instrument panel surround)
MR720570
Sliding Door Handle (Green)
MR727040
Glass Tailgate
MR764125
N/S Mirror To Door Trim (Vertical)
MB952637
Cup Holder (Front)
MR720572
Hazard Light Switch
MR149203
"D" Light Bulb
MR167725
Original Keyfob Transmitter Case
MR502584
MR502590
Original Keyfob For Alarm
MB942997
Centre Console Htr Radio Control
MR727105
Gauge Water Temp (Dash Panel)
MD727105
Handbrake Cover
MR129007
Instrument Nut (Captive Nut)
MB326019
650 Wiper Assembly
MR192015
Headlight Washer Pump
MR416912
Air Lockers
ARB RD 46
Water Pump
GMB Part No. W3115
'O' ring
BS-157
L400 V6 Engine 3.0 1994
Engine ECU
MD199113
Cam Timing belt
Dayco 94495 Replaces T259
Thermostat
MD 174233 (genuine cheaper than aftermarket )
Alternator complete
MD 317119 90 Amp
Extra Alternator Part Numbers
6G72 3.0 V6 petrol engine, built before 3rd April 1997 are fitted with a 100A unit.
MD317119 Alternator assy 12V 100A. (The whole alternator)
MD618913 Rectifier, Alternator. (The diode pack)
MD618696 Regulator, Alternator. (The electronic module that smoothes the rectified voltage from the diodes and limits it to 13.8V DC)
MD618689 Brush Kit, Alternator. (The carbon brush pair that wear down with use)
MD618778 Stator, Alternator. (The outer ring around the alternator with the heavy duty insulated wiring that carries the 100A)
6G72 3.0 V6 petrol engine, built from 1st May 1997 and up to 3rd Dec 2006 are fitted with a 100A unit.
MD350609 Alternator assy 12V 100A. (The whole alternator)
MD619280 Rectifier, Alternator. (The diode pack)
MD619822 Regulator, Alternator. (The electronic module that smoothes the rectified voltage from the diodes and limits it to 13.8V DC)
Fuel Filter
Ryco Z441 or Multifit
Alternator serpentine belt
Bosch 5PK1135
Power Steer serpentine belt
Bosch 4PK955
Or try 4PK970
Aircon V Belt
Mitsubishi SSA921A075W
Or try 4PK990 (MD 186126)
Oil Filter
Ryco Z79A
Fuel Filter
Valvoline VF17
or Z361
Air Filter
genuine - MD620472
Ryco WA489 or A489 or Magna V6 TR model
Crankshaft pulley bolt
1100A141
large washer for crank bolt
MR994412
Upper radiator hose - same as 1997on V6 Triton
Lower radiator hose - same as 1997 V6 Starwagon
