I decided to do a lift kit myself that makes it simple, yet keeps the suspension close to stock.
This is a 1" lift from stock with 31" tires. It's good but 2-3" inches is better and doable. Working on it.
Will be a steel 2" spacer in between the body and the upper, rear coil brace. That way the rear suspension will work properly, ie. spring rate, spring travel.
1" drop bracket for the pan-handle bar and longer gr.8 bolts.
Front will be a torsion bar re-index and crank to level out.
My front end was sagging prior to this 1" lift. After the 1" lift (1.5 inches of upward travel to level it out), the CV / axle shaft now sits level/parallel with the front/rear axle.
Before the lift, there was negative angle on the CV/axles. After the lift, it is now normal.
You can lift the front end by torsion bar re-index/crank up to 3" inches before the CV angle just begins to show signs of steep angles (compared to a 1" lift on the L300 and the CV axle is already close to being maxed).
2.5" pics coming soon.
You can fit 31" tires with the 1-3" lift with a bit of trimming in the front depending on how wide the tires/rims are and what the rim offset/backspacing it.
Because the track width (hub to hub) is a lot wider than the L300, the same wheels that would be flush with the L300 body would stick out roughly 2" from the L400 body. Quite a big difference.
