engine oil recommendations
brewskie
Vehicle: 02 V6 SE
Post by brewskie »
Hi Folks,
Have been running Rotella T 5-40 synthetic since November, looking at changing to something heavier for the summer. Any recommendations?
Rob from Winnipeg
RaddCruisers
Re: engine oil recommendations
Post by RaddCruisers »
You're fine running that grade in the summer, but if it's really hot where you are, then you might want to go with 15W40 or 20W50 - should be a diesel grade oil.
~John
E4 Auto Repair Ltd.
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
brewskie
Vehicle: 02 V6 SE
Post by brewskie »
should I stay with synthetic or go back to reg oil?
I don't think it really matters - I went back to regular 15-40 for the warm seasons but will switch back to synthetic 5 - 40 when it gets near and below freezing again in the fall :M :-D
strada-caster
Vehicle: Mitsubishi Strada 1992
Post by strada-caster »
I thought switching back and forth from syn. to conventional or conventional to syn. was bad for an engine. not recommended etc.
ccautos Glen assured me that switching between synthetic and regular motor oil is not a problem :-D :M
Blackberry
Vehicle: '92 Exceed P35W
Post by Blackberry »
strada-caster wrote:I thought switching back and forth from syn. to conventional or conventional to syn. was bad for an engine. not recommended etc.
Not according to: http://www.synthetic-motor-oil-change-a ... etic-oils/
...but they qualify it suggesting using same brands when switching between Synth & Not.
...and according to these guys: http://www.mobiloil.com/usa-english/mot ... _faqs.aspx
....theirs is fully compatible with non Synthetic:
...and not in answer your question but to share something interesting found while looking for an answer (Synthetic vs. Not & the Environment):
http://environment.about.com/od/earthta ... toroil.htm
(one of) the best things about the internet is the stuff you sometimes find when looking for other stuff
Erebus
Vehicle: 1992 Super Exceed
Post by Erebus »
I read the articles Blackberry gave links to, and I see nothing about switching. The only reference was that mixing isn't an issue.
I went with 5w40 synthetic for the winter, and will switch back to 15w40 conventional for the summer. Haven't heard much to make me change my mind. Going longer intervals with synthetic sounds good, but only if you regularly test the oil and add additives, something I'm in no position to do.
nvanadm
Post by nvanadm »
Ever since I moved back to Ontario from BC i've been using Shell 15w40 because it's easy to find. I don't drive my van through the winter so I'm planning on staying with 15w40.
Just wondering what everyone else uses and if there's a better brand of oil that I should use instead.
Opinions/Thoughts?
Strada 92
Vehicle: Mitsubishi Delica L400 1995
Post by Strada 92 »
Check this:
http://www.delica.ca/forum/4d56-lubrica ... 12202.html
This chart si for 4D56,2.5.
Mitsubishi L400 Spacegear
Mitsubishi I-MiEV 2012
nvanadm
Post by nvanadm »
I will only be using 15w40 as I only drive my Delica during the summer months.
I was more curious about specific brands of oil and why they (you) choose them.
Good chart though!
rezdiver
Vehicle: 1991 L300
Post by rezdiver »
20 liter pails of motomaster 15w-40 diesel oil from canadian tire when they are on sale for around 45 dollars. or whatever else is on sale thats as cheap. they also have their 20 liter pails of shell rotella 15w-40 on sale at times for around 55 dollars.
Reza
1991 Delica L300
http://www.iltisforum.com/
nvanadm
Post by nvanadm »
rezdiver wrote:20 liter pails of motomaster 15w-40 diesel oil from canadian tire when they are on sale for around 45 dollars. or whatever else is on sale thats as cheap. they also have their 20 liter pails of shell rotella 15w-40 on sale at times for around 55 dollars.
Thanks for the input! I appreciate your response.
So basically all oils are created equal? Oil doesn't really change from brand to brand?
nxski
Post by nxski »
Synthetic is definitely different! I'm sure other brands differ as well, but I'm not sure how... :?
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
I always run 20L pals of Rotella in all my diesels never synthetic for me (I change it so often it is not worth the expense and Vancouver temperatures do not warrant the better flow at cold extremes)
Oils are not all the same...One research study showed that keeping the same type of oil in a motor for life (constant oil was more important then brand) and it showed life of the motor would be longer. I stay consistent always Rotella and always change every 4,000km unless extreme use (work) then I change about 3,000.
