ok so I installed my new glow plugs awhile bag, but the Delica continued to give me grief in the cold. The initial glow plug relay doesn`t click off until almost 2 minutes when it is -4 degrees celsius. When the engine is warm it can still take 60 seconds before it clicks off. I am not talking about the 2nd relay that switches off once the engine reaches operating temperature.
I put a multimeter on the busbar and found that when the ignition is switched on the voltage meter takes its sweet time (as I said 1-2 minutes +) counting up to 4.6 volts and then it switches off the circuit.
If I advance the key further to the point just before ignition, it will again count up to 4.6 volts and shut off the circuit.
I think I have the quick start circuit
what gives?
glow plugs again...
- lost1
- Vehicle: Subaru Sambar SC
- lost1
go on http://www.ih8mud.com, enter the forums, diesel tech and search for "wilson switch" there are some good write ups there...
actually if you do a read on that forum you will cmoe across much info that crosses over to the diesel delica applications
(i am crushers there too)
