Shocks...Rancho, Monroe, etc...
DeliMilkMan
Post by DeliMilkMan »
Hi there
I am STILL looking to find shocks that fit my Deli! I have searched here, (NS) called BC, talked to UK, and nobody has info on what shocks actually fit. I tried all the links in Canadian Parts, and no luck with any of the numbers. KYB, Gabriel, etc. Has anybody actually changed shocks on the vans yet? If so, I would request an actual part number from the shock, not a store stock number, which apparently those numbers are in the parts list found here in the forum. I Beg, if anybody has replaced a stock shock front and back, please tell me where to find them, you can even tell me where to go if you say it with a smile... :wink:
Geoff
BCDelica
Vehicle: WVO Powered Tuk Tuk
Post by BCDelica »
Thanks to UK Mark G
Hi guy if you are thinking of replaceing your shock absorbers on your l300 delica then get in touch with explorer pro comp and order some of these es9000 gas shocks part numbers that i have used are for the fronts and rears 913515, 919520 two of each hope this is some use to you all
I took those part numbers to my part store and they set me up fine 2 years ago, made a nice difference on the logging roads.
Image Call me BCDelica-less
Leafster
Vehicle: L300 Deli
Post by Leafster »
I just ordered a set of ES3000 from North Shore Off-Road. They are the same as the ES9000 except not gas-charged. $55 each I think
Part numbers 313515 front
319520 rear
They also have a special on 8% Pro-Comp off-road lights for $48 each, ordered a couple of them too, so stoked.
Even though it's the girlfriend's van, it's more fun to mod than my '07 Tacoma!!!
