headlight change
northvanmatt
Vehicle: 91 super exceed
headlight change
Post by northvanmatt »
Hey I know that this sound alittle silly but I can't figure out how to change the headlights. I bought the right e-code lights so I can pass inspection but I can't get the old ones out. has any one had the pleasure?
thank you very much
Jungle Jon
Vehicle: Toyota Tacoma
Post by Jungle Jon »
First you need to remove the side indicator light pod which is attached to the piece of trim that runs underneath the headlight - one obvious screw on the side of the indicator pod, and two screws on the trim piece underneath the headlamp. These are deep in the recess between the trim piece and the bumper, and can be rusty so be careful not to strip them. Once the 3 screws are out, the indicator pod slides out towards the front of the vehicle.
Next, there are 3 machine screws with washers that should be easy to get at, remove those, making careful to support the lamp on the last one so it doesn't fall. Unclip the wires, and you're done! 8)
delicanuck
Funny you should say that.
Post by delicanuck »
Hi Matt,
Tim ("username") and I just pulled a headlight on his van on Saturday in order to goop up his leaky corner panel. Obviously Jon has done this too and his directions are 'spot on', as Bruce would say, but if you haven't all the required tools or if you need a covered space to work or you can't find those bottom screws, let me know. I'm in Lynn Valley.
Brett,
89 Exceed,
There are really only 10 kinds of people in the world;
Those who understand binary and those who don't.
northvanmatt
right on thank you for the quick reply i wll let you know how it goes!
argo
Post by argo »
You'll have to change the plugs. The wiring is out in the weather so you might want to invest in some liquid electrical tape and heat shrink tubing to make your connections water tite.
northvanmatt
I got it done it took me 2.5 hours(whoa) I thought it would be just a quick job man I was wrong oh well saves me paying somone else to do it. thankyou for all the help everybody I don't know what I would do with out this site!!! :D
