** Parts list and requests for bits from UK **
Mystery Machine
Post by Mystery Machine »
USED PARTS UPDATED 7th FEB.....
Seeing as I will be coming over on the 18th March for definite, I have decided to pack just the bare essentials and use most of my luggage allowance to bring over parts for you guys.... :D :D
I'll break it down into 4 areas:
:arrow: New parts that you want me to buy for you (service items etc)
:arrow: Parts that I make
:arrow: Used parts that I have got
:arrow: Used parts you would like me to try and get
Obviously I won't be able to bring everything over and I have to consider size as well as weight (so NO ladders or rrof crates I'm afraid! :( )
Please use this thread to list things from any of the four categories and I'll see what I can do. Please do not PM, keep it public and so will I, so that everone else can see what I'll be bringing or what I have or what I can get....
I hope this makes sense?
Regards,
Bruce.
1) New Parts
(to be updated with parts and prices - let me know what you are looking for....below are just some examples)
* Anti-roll bar polybush kit (Josh Interested)
* CV and steering boots (Argo interested)
* Belts (alt/steering/cam etc..)
* head gasket
* brake pads (ferrodo - better than standard)
2) Parts I make (I'll upload photos next week)
* MM Heavy duty 2" shackles (gives the rear a proper 1" lift) $190
* MM 316 grade stainless steel wing mirror arm kit (replaces rusty chrome or black ones) $175
* DELICA Mousemats (photos next week) $12
* DELICA Mugs (photos next week) $12
* DELICA Stickers (photos next week) from $3.5
* DELICA Seat belt pads (would need min order of 20+) $25 pair
* DELICA T-shirt (not definite!) $25
* MM stuff like other stickers, mousemats etc....
3) Used parts I currently have
* Turbo pressure relief valve $35
* Rear bumper/nudge bar end caps (Reserved for JOSH)
* Genuine yellow front fog lamps & clips (pair A) $95 (PHOTO)
* Genuine yellow front fog lamps & clips (pair B) $105 (Reserved for DELICANUCK) (PHOTO)
* Various rear interior pockets (7 of large, 3 of small) $10 each (PHOTO)
* Exterior handle/lock/door edge protector complete set VERY RARE!! $70 set (Reserved for FANNY BAY DELICA)
(PHOTO)
* Quad/square pre-1990 headlamps (1 complete set) $35 per unit (PHOTO)
* Front indicator units (2 of each side) $22 each (PHOTO)
* 3 way map/interior light $35 (Reserved for BREADMAN) (PHOTO)
* Square interior light (2 of) $20 each (PHOTO)
* Rear ashtrays (3 of) $10 each (PHOTO)
* Chrome DELICA & Mitsubishi badges $10 each (PHOTO)
* Rubber inner door protector (drivers side) $8 (PHOTO)
* Rear vents & map light unit (2 of) $35 each (PHOTO)
* Square (pre 1990) headlamp surrounds (2 of each side) $35 each (PHOTO)
* Speedo pod (needles ARE included!) in MPH! $70 (PHOTO)
* Interior grab handles (8 of) $10 each (PHOTO)
* Rear Audio Stage roof speakers complete set VERY RARE!! $80 (PHOTO)
* Rear cab roof vents (4 of each) $10 each large or $5 each small (PHOTO)
* Lower trim panel (behind front wheel) $20 each (PHOTO)
* Electric roof blind switches (2 of) $20 each (PHOTO)
* Lower headlamp trim (projector lamp type) $20 each (PHOTO)
* Rear heater control panel (2 of) $20 each (PHOTO)
* Front or rear heater knobs (4 of) $3 each (PHOTO)
* Front ashtray $15 (PHOTO)
* Rubber dashboard mat (got a missing centre pod - this covers the gap nicely!!) $15 (PHOTO)
* Front parking mirrors VERY RARE!! (no arms - just the mirror head) (2 of) $20 each (PHOTO)
* Centre console tray and window switches $30 (PHOTO)
* Sliding door central locking contacts $10 for both (PHOTO)
* Roof blinds front switch (2 of) $10 (PHOTO)
* Rear fan switch (from dashboard) $15 (PHOTO)
* Rear wiper & hazard switch $20 (PHOTO)
* Tool compartment strap (holds jack handle & tools in place) $3 (PHOTO)
* Heated rear window switch $10 (PHOTO)
* Alloy rocker cover (V good condition - will be cleaned!!) $35 (PHOTO)
* Alloy inlet manifold (V good condition - will be cleaned!!) $95(PHOTO)
* Bull bar corner piece/cover (pre-1990) $30 (PHOTO)
* Passenger side rear lamp unit $60 (PHOTO)
* Front electric winder units (complete) $60 each side (PHOTO)
* Central locking solenoid (sliding door I think?? :? ) $25 (Reserved for MITCH) (PHOTO)
* Sliding door handle/tailgate catch $5 each (PHOTO)
* Rear heater blower fan unit $70(PHOTO)
PLEASE NOTE - some of the parts may look dirty or grubby - but all these parts are in excellent condition and will be properly cleaned before packing and bringing with me.....please don't be put off by the photos!! Some of the bits have been hanging around in my friends workshop since being taken off the vehicle!!
PLEASE ALSO NOTE - I will be completely STRIPPING the rear interior of my 'Mud Monkey' L300 along with the COMPLETE air conditioning system!! If there are any parts you would like that are not listed here, please ask and I'll give you a price!
ALSO - The COMPLETE rear seatbelt set-up for a 7 seater (including the wall mounted inertia 3 point belts) is up for grabs for $285 This will include all mounting bolts, all clips and even the plastic surrounds where the belts come out of the vehicle sides. This price is based on the complete system + the huge amount of weight and space it will eat up in my luggage allowance!! (which means less stuff for other people!!) I will take photos of the complete seat belt set-up once it has been removed from the Deli...... :wink: (RESERVED for BREADMAN)
(I'll add more if I find anything else... :wink:
4) Parts you are looking for/need
Please let me know of any parts you are looking for and I'll see if I can source them for you..... :D
Last edited by Mystery Machine on Sat Feb 24, 2007 3:53 pm, edited 7 times in total.
Breadman
Post by Breadman »
hi bruce, thanks for the offer. does the front map light replace the older style . can i pull off the one i have and replace it with the newer style that you have. i assume it is the newer style with the two small map lights and the larger interior light attached. mine has the older slide rectangle without the map lights. if i can just replace it as i think it must be possible consider it sold.
paul
Fanny Bay Delica
Post by Fanny Bay Delica »
Bruce,
Sign me up for the stainless wing mirror kit. Is is passenger or driver/passenger, as only my passenger wing mirror bar has some surface corrosion (only rust I could find on the vehicle), all other components on the mirror are fine?
Cheers!!
Andy
Kuan
Vehicle: 94' L400 SWB
Post by Kuan »
Hi Bruce,
I'm looking for cinch up type seatbelts for the captains chairs. I have the standard inertia locking ones that are no good for child/baby car seats. If you have any there or know of where to get some, I will gladly pay for them.
Cheers.
Kuan
delicanuck
Authentic Fog Lamps?!?!
Post by delicanuck »
Hi Bruce,
Still have those original fog lamps? Still got room in your bag? If yes to both, I'd like to buy those lamps! If you happen to have mounting hardware/wiring hardware, I'll buy that too. Gee! It looks a bit like your having a moving sale.
Brett,
89 Exceed,
There are really only 10 kinds of people in the world;
Those who understand binary and those who don't.
BCDelica
Vehicle: WVO Powered Tuk Tuk
Post by BCDelica »
Bruce could you put me down for two DELICA stickers! $3.50 is a steal.
Would you be able to source out an exhaust manifold? I have a pin hole leak on the 1990 and think I should tackle it as soon as possible.
Are those the quad headlights mounting assemblies! If so that would be great to mount on a 1991 or newer to pass inspection and run some cheaper replacement lights. It was a big improvement on my 1990 changing to high quality, readily available, and properly aimed lights. For someone around here needing to pass inspection on a new arrived Delica this be a economical option. :D
I don't want to order too many heavy things; Just imagine Bruce stuck in major airport trying to explain the large and oddly shaped pieces of metal in his luggage. :lol:
Image Call me BCDelica-less
josh
Vehicle: L300 poptop gasser
Re: ** Parts list and requests for bits from UK **
Post by josh »
Mystery Machine wrote:* MM Heavy duty 2" shackles (gives the rear a proper 1" lift) $180
Bruce,
How do you get a lift out of the front? Will the torsion bars wind it tall enough to match the 1" lift on the back? If so I am up for that (maybe I'll PM you)... and do you know of any heavy duty torsion bars for the Delica?
Oh and sign me up for a couple DeliCA stickers, and a few MM stickers as well. Thanks. How many more days now?
Josh
Mystery Machine
Hi Guys,
I'll get around to answering your requests tomorrow - it has taken me most of the day to dig out, photograph, price and list all the items above! (the list has been UPDATED with lots of new parts and is now complete with photos of each item!! :D :D )
Check out the new list and see if there is anything you want/need.
I have tried to list things that I know I can pack in a suitcase.
The price of the 'newer model' complete seatbelt system is based not only on the whole system, but also the fact that it will take a LARGE proportion of my luggage allowance (both size & weight!), so I have priced it accordingly!
Hope this all makes sense??
Regards for now,
Bruce.
P.S. I'll update the pics of the new parts later this week.... :wink:
P.P.S. Sorry Josh - I priced the rear lift shackles wrong! They are $190 not $180!!! SORRY!!!! :oops: :(
Kuan
Post by Kuan »
Hi Bruce,
Regarding seatbelts. If you are willing to split it up, I would like either:
2 x 3-point seatbelts for the rear captain chairs
OR
2 x cinch-up seatbelts that I could replace the inertia seatbelts with.
If its a hassle no big deal. It would just be a clean solution for putting the children in those captains chairs.
Oh and MM gear for me please!
Kuan
northvanmatt
Vehicle: 91 super exceed
Post by northvanmatt »
Hey Hey bruce right now I don't need any parts but, right on bro. Thankyou for helping out all us canadian delica owners your going above any beyond.
mitch
Post by mitch »
how bout some of the trick fender flares you have on your rig, but in black???
Mitch
mitch
Post by mitch »
Hey I'll also take that sliding door lock solinoid... if thats what it is.. mine is starting to groooooooan.. its on its way out.
Mitch
mark
Member's Photo Album: http://www.delica.ca/Photos
Vehicle: 1994 L400
Post by mark »
Bruce -- I'll want three of your Delica stickers for my own use. As I'm still "without Delica", one sticker will be proudly displayed on my Mercedes 300D; the other in my Odyssey van. The third decal will (of course) be reserved for my (soon-to-be-located) new Delica.
As I mentioned to you by phone, I'll be pleased to serve as local distributor for the official Delica stickers, etc. once you return to the UK.
-Mark
Thomas Porter
Need parts
Post by Thomas Porter »
Hi Bruce,
I need some fender flares for my 91 L300. Any chance?
Thomas Porter
thomas@smarterphoto.com
Population Density; One person per square kilometre. Just the way I like it...
