Intermittent higher idle
deskinthewoods
Vehicle: 1991 L300 Star Wagon named "Wilson"
Post by deskinthewoods »
I noticed the other day, at a stoplight, that the idle was up around 1000RPM. Normally it’s 750RPM. I made a mental note to adjust it but when I got home it was back to 750.
Next day, back up to 1000. Got home, 750.
Any ideas what would cause this?
lrp374
Vehicle: 91 Super Exceed
Re: Intermittent higher idle
Post by lrp374 »
I had this problem several years ago. It would happen in the late fall and winter whenever I when over 3000' elevation. In the summer it would rarely happen. I was told it was likely the governor sleeve sticking. I decided it wasn't a big problem so left it until I needed to get the I/P pump rebuilt. After I had that done it never happened again!
deskinthewoods
Hmmmm. I rebuilt the IP last year...
Like you said, not a big problem.
