Hey there!
I'm a new Delica owner (2002 L400 V6) and want to have a few things replaced before I take him out on the road for any kind of long trip! I've been told it's more cost-effective to order your own parts rather than have them sourced by a mechanic? How true is this?
In particular the parts I am after are a new fuel filter, a new engine filter, spark plugs - can any of these be ordered through Lordco/NAPA or should I order them from Coombs or Rising Sun? I am having a hard time figuring out how to cross reference the OEM part numbers with the appropriate aftermarket part numbers - are there good resources/reference lists for this anywhere? (I tried searching the forum first with no luck!)
L400 Parts - Cross Referencing part numbers for Napa/Lordco etc?
- Vehicle: Mitsubishi Delica
- Vehicle: 94 Strada
If you're going to order them, you might as well order them directly. I use fitinpart.sg for filters and other wear items - use your VIN number to confirm - fuel / oil filters are about $11-13 each. For "other" parts try partsouq or amayama, again use your VIN number to access the proper ones.
Ralph in Winnipeg
Ralph in Winnipeg
- Vehicle: 2002 L400 V6
Once you have the part number from partsouq or fitinpart, you can cross reference it with Rockauto, Lordco, or the Mitsubishi dealership. I get my fuel and air filters from Lordco or Rockauto
For Rockauto you will have to click on the "part number search" tab, otherwise it doesn't work
- Vehicle: L40
Re: L400 Parts - Cross Referencing part numbers for Napa/Lordco etc?
Hi, I have access to the original parts for L400 here in Canada, please drop a line if interested.
