So I've gathered info from the internet for oil filter part number.
Crossed them to napa Canada, and got 3 different filters
1067 (most expensive and 30 micron)
1675 (19 micron OEM suggest 16+)
1809
The first 2 has the same dimension
However the 1809 is a bit taller (same as current from Mardy) but slight difference in Gasket OD (2mm) when I compare it with the first 1067 and 1809
I got these numbers from different sources on forums.
Does the length of the filter matters? What does everyone use?
Current one on mine is from Mardy but he's out of town...
I'll have to do mine in a few days before heading to kelowna then Oregon and looping back via Vancouver and finally back to the Rockies.
J
Do you use napa oil filter? If so which one?
- Vehicle: Delica 99, 2.8TD, Superexceed
- Vehicle: 1996 delica
anyone find any options at lord or napa?
- javabob
- Vehicle: 1991 Exceed (P35W)
I've used the Napa 1067 and had no problems with it.
Recently I've been ordering from fitinpart.sg. They have great prices and although they are in Taiwan I received my order in 4 days.
They sell JS Asakashi and Azumi oil filters for around $9 USD.
- Vehicle: l400
I have one sitting on my desk at work. I tell you tomorrow what the napa number is.
- Vehicle: l400
I use a 1675 with no problems
- Vehicle: Subaru Forester
Are these part numbers for the 2.8 diesel guys?
Sent from my LG-M703 using Tapatalk
Also check out the Delica FAQ Section (see in board index). There are a few cross reference threads in there. Last time I went to Napa, they wanted to sell me an oil filter for $45. I go to Maximum Overdrive (in Richmond, BC) and buy half a dozen at a go, better deal. Maybe he ships?
