My L300 is in serious trouble
- Vehicle: 1992 Delica L300
Hello All,
Iv been following this forum and the other for a couple years now and been patiently waiting till id be ready to spring on a Delica. Well 4 months ago that happened and i picked up a 1992 L300 with around 168,000 kms on it, iv been driving it for about 3 months now and other then getting new glow plugs after extreme cold start issues its been running tip top, no issues with the trans and no bad sounds.
A couple weeks ago i started getting a small minor oil leak i took it into a well respected local shop that has Delica experience and they hit with me a doozy.
Here is there quote for the work i need done immediately:
https://drive.google.com/file/d/0B9W8h0 ... aaEpJ/view
It seems the bulk of the 5000$ is in the 2200$ injection pump
What im struggling with is whether or not i have any other options:
Could i do any of this work myself? I have access to a dry area and tools plus weekends id be happy to give up to do this.
If i get all this work done and bite the bullet will i just have more issues down the road? She might just be a lemon?
Thankyou for your time and im sorry to bother all of you with this newbie centric post
-Nicholas
-Nicholas
Reason: Fixed external link
quote won't open.
MD
MD
- north54
- Vehicle: 1989 P35W
What are you talking about as far as oil leak goes? drip every now and then? I've had a small oil leak in my Deli since I got it 3.5 years ago and it still keeps going...
The slight oil leaks seem to be quite prevalent in Delicas and can mean a variety of things from a leaky head gasket to a defective engine oil drain bolt washer.
If your timing belt is definitely due for a change then bite the bullet and get that changed asap or you won't have an engine in the future.
Did the shop mention where your leak is coming from? I couldn't see anything in the quote they gave you...
TRUSTY RUSTY
- Big-Bird
- Vehicle: 96 PE8W Spacegear
The fuel pump rebuild by itself isn't a very hard job....The timing can be finicky.
All the other work they quoted you... Belts, seals, waterpump....Are general maintenance items that can be done by anyone with decent mechanical aptitude. It's just time of course.
Did you contact Commbs Country Auto and get a second quote?
- Vehicle: Mitsubishi starwagon
You can get a timing belt kit with water pump for $179 on ebay here in australia the dearest timing kit is $500!
Sent from my SM-G900I using Tapatalk
- ChuckBlack
- Vehicle: L300 Jasper
I get all my stuff front Rising Sun Imports!!! The timing belt kit is around $500 and comes with all you'll ever need! crank and balancer Seals, WP, tensioners, belts! I've had a oil leak too since my i had mine too... the way i see it... rust protection!
L300 Jasper,
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
L300 Chamonix,
Pajero Mini,
Pajero GDI
Pajero DiD
I would take the top timing belt cover off and see if there's oil on your belt and if it's coming from the fuel pump. 10mm socket with a small extension and ratchet is all you need.
Also I too have had a loonie size oil leak for 10 years. I just don't park in my father in laws driveway.
- Vehicle: '91 Delica L300
$2200 for a pump replacement instead of just replacing the seal in it? It can all be done with basic tools/skills, but it will take quite a bit of time... I would guess ~2 full days. The information on how to do all of it is available online here and elsewhere.
Steven
1991 L300
Harrisburg, PA
1991 L300
Harrisburg, PA
That quote makes me very uncomfortable. Please, please get a second opinion.
$1200 for the items in the timing belt kit is outrageous, and they're easy to replace yourself if you have a bit of mechanical inclination, and follow Tojo's thread and the workshop manual.
The only time you'd rebuild your injection pump to the tune of $2200 is if you were having serious drivability issues- black smoke, won't start, cutting out. Even then, $2200 is on the waaay high end and would have to include rebuilt injectors.
An injection pump rebuild kit is $32: http://www.ebay.co.uk/itm/Mitsubishi-Di ... 1840489414
*checks airfares to YVR*... Hmm. For $5000 I could buy all the parts, fly to YVR on Air New Zealand, pay myself $125/hour to install them over two days, and fly home again. Hypothetically, of course, as I'm currently on vacation at the beach.
- Vehicle: 1992 L300 P35W, White
I can't open the quote. Which shop gave you the quote?
Try again, I've fixed the links.sealica wrote:I can't open the quote. Which shop gave you the quote?
- ynwa
- Vehicle: L300 Starwagon TD
Hey, fellow Victoriite, Victorian? Unfortunately Marigold seems to have a monopoly on JDI vehicles and they know it. I've heard some pretty terrible stuff about that shop and the condition of my L300 van when it had apparently been in there recently.
Oh, the top of the timing cover should have a sticker with a mileage number on it. This will be when the timing kit was last changed (hopefully).
A little oil leak could easily be the $4 half-moon plug at the back of the rocker cover. If it runs well and looks balanced, I wouldn't panic, but see if you can give it a good degreasing and then follow the leak from the bottom up. You might just find it's leading up to the back of the rocker panel.
We need another JDI shop in Victoria!!
1991 L300 TD Low Roof
1992 L300 TD Low Roof
1992 L300 TD High Roof
