L300 Front Head Light Alignment
Asintha
Vehicle: PO5V
Post by Asintha »
Hi Experts,
I have one questions. Recently i have lifted my delica l300 now i am feeling the front head light needs to be align little more downwards. How should i do it? i have seen some adjustable nuts are available in each bulb. Can i use those? which side i show turn those nuts in order to get the head light beam little more down.
Thanks and Regards
Asintha
motorang
Vehicle: L300 P25W
Post by motorang »
Hi,
depending on your model I guess. The latest facelift there was in Europe had electric headlight adjustment, but you also could use the 8mm hex and crosshead screws under the reflectors.
This is how it works: remove the indicator to get to the adjustment screws.
Orange are the adjustment screws, red is the direction they adjust when turning the screws counter clockwise.
German but some pictures: http://www.motorang.com/L300/L300_4x4_T ... htm#lampen
Andy
Asintha
Vehicle: PO5V
Post by Asintha »
Hi Andy,
Thank you very much for the update.
If anything ill post it here
Thanks again
