Hi all own a 2003 L300 4x4 2.5TD LWB. We started last year with the restoration process. Our goal is the use the L300 this summer as a campervan.
Here are some pictures.
http://s30.postimg.org/ivu69uc5t/IMG_20 ... 130412.jpg
http://s11.postimg.org/i0ju5ftkj/IMG_20150620_WA000.jpg
http://s21.postimg.org/fjvqo1uyf/IMG_20 ... 131805.jpg
http://s21.postimg.org/nhur3fxmf/20151031_141858.jpg
Hello from Switzerland
- Vehicle: L300 2.5TD 4x4
Re: Hello from Switzerland
Hi Zoomer, welcome to Delica Canada
Looking forward to seeing more pictures as your restoration progresses. Looking at the pictures so far it looks to me like your wagon is a SWB rather than a LWB. Good to have you with us... smiles.
Hi Falco
Thank you for the warm welcome. The L300 is a LWB maybe you cannot see it on the pictures that i have posted, but here is one were you can see it.
http://s30.postimg.org/7uuzxntrl/IMG_20 ... 161749.jpg
I have a lot of other pictures, i will post as soon i have more time.
How long from axle to axle?
Very nice! Not many LWB 4WD L300's out there. Looking forward to seeing what you do to it!
(LWB differentiation points: rear wheel arch starts about 200mm from the sliding door, roof has an extra panel at the back to make it longer, rear windows are longer than middle/door windows, sliding door track isn't long enough to fill the depression in the panel.)
Hi, i dont know the exact lenght, in the vehicle papers is it also notice as L300 2.5TD 4x4 L.
And the roof has an extra panel. you can check also the side panels, the rear one is longer then the door panel were the window should be.
Short: http://cas01.autoscout24.ch/mitsubishi- ... 119/13.jpg
Long: http://s30.postimg.org/7uuzxntrl/IMG_20 ... 161749.jpg
This weekend we have to change the alternator, and the all should be fine with technics. About in a month we will start to build the inside, maybe you can see it on the last picture we have installed a fantastic vent roof window.
