L300 A/C Schematic
subabus
- Vehicle: 1993 Delica Star Wagon
L300 A/C Schematic
Looking for the relay switch on my a/c unit. My air conditioner is fully charged but is no longer engaging when I press the button - no click and no cold air. Does anyone out there have the schematic for the a/c or any info that will help? Thanks.
Re: L300 A/C Schematic
L300 Dedicated Category Reference Forum/L300 Shop Manual Downloads.
No schematic exists that is for the L300. I looked off and on all last winter after my A/C quit last year. I took it apart this spring and tried to trace wiring. I quit when I found the problem was one of the fusible links. It would let voltage through but not enough current to power the relays. I replaced the wire and connector and it's worked great so far this year. If you have questions let me know and I can try to help. The Lazy Green Fox has also worked on these and helped me a bit with the general operation.
Larry
Larry
