Torn boot on front axle and other questions
Mazdax605
Vehicle: 1989 Delica P25W
Post by Mazdax605 »
Hey guys,
Well after having my van a couple of weeks I finally got around to climbing around under it. What I found was a torn boot for the left axle, and that wheel doesn't seem to rotate very easily by hand. What I mean is that the right side turns with little effort, but the left is pretty stiff, and doesn't continue rotating much after you put some force on it. Is it related to the torn boot possibly? Doesn't appear to be brake related as the van doesn't pull to either side, and both sides felt the same temp wise. Wheel bearing? Where can I get the new axle boot?
Also I noticed the front drive shaft turns with the wheels. Could I put on manual locking hubs to disconnect the front axle from the wheels when in 2wd? If so where would I order them, and what part number? Is replacement of the boot difficult? I think replacing the ball joints would be wise while in there as the lowers are a bit questionable. Where is the best place to get these parts?
Chris
89 P25W L300 Aero GLX
74 Mazda REPU
78 Mazda RX-7 GS
Tojo
Re: Torn boot on front axle and other questions
Post by Tojo »
Manual hubs: http://ccautos.ca/parts/4wd-manual-fron ... embly.html
Plus a lot of other goodies.
Other parts here: http://www.amazingautoimports.com/categ ... 300_parts/
and here: http://rs-import.ca/shop/step0.php?orde ... &pagenow=1
Also, check out this post: http://www.delica.ca/forum/delica-parts-guide-369.html
A lot of parts cross to North American brands available at Napa, Rock Auto and others.
