Rear Bearing Type
FredVenne
Vehicle: L300 Exceed Pop-Top, Pajero Exceed
Rear Bearing Type
Post by FredVenne »
Good day!
I have looked in the forum and could not find anywhere what type of bearing (tapered or ball or both) is needed. In WIKI it says it is a L200 rear bearings.
So my question is, can you put a tapered bearing or should it be absolutely a ball bearing? If it is a ball bearing, where can I get'em?
Fred
P.S. Still stuck at the mechanic with more and more problems...
-The Mighty Yeti
Firesong
Rear Bearing Type
Post by Firesong »
Aren't these br50 bearings? Get them from the local bearing and tranny shop.
Firesong
Rear Bearing Type
Post by Firesong »
I'm looking for my back up info and can't find it. I'm positive that's the right part number. I had a set of extras and gave them away with my l300 when I sold it. Ill do some more checking.
Firesong
Rear Bearing Type
Post by Firesong »
A couple links
I'm sure it's the same bearing used front / rear
http://www.delica.ca/forum/trying-to-fi ... -8173.html
There is a lordco parts sheet showing br50
http://www.delica.ca/forum/need-to-remo ... -5992.html
-This one shows napa part numbers. Although I'm sure mine came with the race etc
I'm sure this will all be confirmed by getting which ever shop to search for the bearings under Mistubishi Montero 1988
FredVenne
Re: Rear Bearing Type
Post by FredVenne »
Thanks Firesong!
My mechanic decided to machine the wheel so the bearing I got would fit. Nothing major. But I will look into it when I'll be in NS.
Thanks!
-The Mighty Yeti
