Finally installing a pyro on my L300.
One question, where is the best place to hook into power for the gauge? It will be going in the 3 gauge pod.
Pyro (EGT) Install. Best place to get Power?
- bionic
- Vehicle: 92 delica exceed
Re: Pyro (EGT) Install. Best place to get Power?
I ran my pyro off the ign power for the stock radio.. Can't remember the color, just used a volt test light until I found the correct one. If you currently have a player, simply sister the power supply to the ignition power. Closest power source, and a pyro should take little draw;)nvanadm wrote:Finally installing a pyro on my L300.
