Greetings everyone,
Kudos to this site for being available to the masses, it is much appreciated. Does anyone know where I can find schematics for installing the Plantdrive SVO system? I've got everything I need, would feel a lot more comfortable seeing schematics. Much appreciated, thanks!
Ryan
Plantdrive SVO Schematics?
- Vehicle: L300
- Vehicle: Mitsu Paj
Re: Plantdrive SVO Schematics?
I would like to bump this post up. Just acquired a never used kit myself, and a schematic or blue print would work wonders.
- Vehicle: 1995 Royal Exceed
- delicat
Here's how I set up my valves. Obviously, the default valves position is not powered while on diesel (so if you loose power to them you're not stucked on wvo). If you plan on using an inline fuel pump I'd move the Wvo return line between the supply valve and the IP so that left over oil blends in with the fresh diesel... If no inline pump than it would simply findings way back into the Wvo tank as drawn.
[img]http://img.tapatalk.com/d/13/07/05/vyte5usa.jpg[/img]
Is this what you were looking for?
Mr. D
Mr. D
- Vehicle: L300
Thanks Mr. D, that should help some. That being said, anything else out there would be of help as well!
...and to Glenn, ues, the Vegtherm is the one I'm talking about. It comes with instructions from the fellow out of (Salmon Arm?) but a diagram of sorts would be superb.
Thanks!
Thanks!
