Rain deflector fit problem
Posted: Mon Apr 22, 2013 11:39 am
by nishby
Does anyone know the secret to installing aftermarket rain deflectors on an L300? The one's I got from Mardy are a bit too long, and too thick to allow the window to go up all the way into the slot.
Has anyone dealt with this?
Shane
Re: Rain deflector fit problem
Posted: Mon Apr 22, 2013 11:47 am
by yojimbo
There's 2 breed of deflector, one that goes in the slot alongside the window rubber, and one that sticks outside on the doorframe with tape. Assuming you have the former, and arent trying to stuff the latter into the window frame
then when I fitted similar deflectors to mine I found it easier to remove the window rubber, and trim the small lip off the edge thats inside. Fitting the deflector takes up the gap you trim off.
Posted: Mon Apr 22, 2013 11:59 am
by nishby
Thanks but Mardy just pointed out that I have the first type, which in hindsight should have been obvious.
Posted: Mon Apr 22, 2013 12:47 pm
by yojimbo
Right, well you could try as i did and trim the rubber lip off.
