There's 2 breed of deflector, one that goes in the slot alongside the window rubber, and one that sticks outside on the doorframe with tape. Assuming you have the former, and arent trying to stuff the latter into the window frame
then when I fitted similar deflectors to mine I found it easier to remove the window rubber, and trim the small lip off the edge thats inside. Fitting the deflector takes up the gap you trim off.
