How to tell if vehicle has ABS?
- Vehicle: 1996 L400 Exceed
Hi all
Sarah and I are new to the forum and neither of us are very mechanically inclined. We do however hope to change that and become more knowledgeable about our new Delica.
Can anyone tell us if there is an easy way to check if a Delica has ABS? Our vehicle is a 1996 L400 hi-roof lwb Exceed. The vehicle did not come with a manual so we can't check that. Any ideas?
Thank you
John & Sarah
Thank you
John & Sarah
Re: How to tell if vehicle has ABS?
Drive down a quiet gravel road, jam on the brakes, and if the brake pedal pulsates beneath your foot - ABS.
- Mr. Flibble
When you insert the key, into the ignition and turn, you should see a number of lights blink on. One of these will be a yellow circle with "ears". It should say ABS inside the circle. It just blinks for a split second then goes off.
If you see that, you have ABS.
Or slightly warped rotors?mararmeisto wrote:Drive down a quiet gravel road, jam on the brakes, and if the brake pedal pulsates beneath your foot - ABS.
Thanks for the suggestions. Can't get away to drive down a gravel road at the moment but did check to see if there was an ABS light and there wasn't. So, I have to assume there is no ABS on the vehicle.
Thanks for your help.
- Vehicle: l400
Now you're just getting technical fredt, what with a picture and all.
- Vehicle: l400
mararmeisto wrote:Now you're just getting technical fredt, what with a picture and all.
fredt wrote:you should have that lump of alloy along with a load of brake lines stuck in the engine bay if you have ABS?
I've had a look in my engine bay and can't see anything like the device you pictured. So, with the absence of that, and no ABS light in the dash, I think I'll have to concede the fact that my Delica does not have ABS.
Thanks to everyone for your help.
That's a good sign, less to go wrong!delicajohn wrote:fredt wrote:you should have that lump of alloy along with a load of brake lines stuck in the engine bay if you have ABS?
I can't believe the vehicle failed for ABS not working, the ABS never worked in my Mighty Max and it passed just fine.
Yep, less to go wrong but also less to help you avoid death when you're skidding towards a jack-knifed semi on a slippery highway.nxski wrote:That's a good sign, less to go wrong!![]()
ABS has its ups and downs, on some surfaces it's better, on some surfaces it's worse.delicajohn wrote:Yep, less to go wrong but also less to help you avoid death when you're skidding towards a jack-knifed semi on a slippery highway.nxski wrote:That's a good sign, less to go wrong!![]()
- glenn
There are very few people that have the level of finesse to sense when their wheels are locked and are able to back of on the brakes enough to maintain braking, while ensuring that wheels are still turning enough to maintain steering (if anyone). So, all you can do is pump the brakes (brake,steer,brake,steer . . . ) And trying to do this during split second collision avoidance is that much more challenging.
It's true, that in some situations, a vehicle with it's wheels locked up will stop faster than one with it's wheels not locked with ABS - BUT that vehicle with it's locked wheels is an uncontrolled projectile.
The real problem with ABS brakes is the proverbial nut behind the wheel. ABS cars tend to roll over more because steering is maintained and many people over steer when they panic. High speed panic stopping should be a basic part of all driver training. Highway speed to 0 at maximum braking is adrenaline inducing at the best of times.
