L300 stuck in 4wd - relieve tension to unlock?
dfnder
Vehicle: '91 Exceed
Post by dfnder »
I have tried a few of the suggestions to unlock the 4wd but so far nothing has worked. I was wondering if it is possible to relieve the tension in the transfer case to allow it to switch out of 4wd? Any body able to give insight what linkage to disengage to allow me to get to 2wd? Is it a big job?
Cheers and thanks, Peter
dfnder
Vehicle: '91 Exceed
Post by dfnder »
Firesong
Post by Firesong »
Driving backwards didn't do the trick?
yojimbo
Re: L300 stuck in 4wd - relieve tension to unlock?
Post by yojimbo »
Driving backwards will, I think, only unlock the hubs, when its already in 2WD, I think the issue is getting it out of one of the 4WD positions that the lever is currently stuck in.
I would start by jacking up a wheel and seeing if the transmission is wound up and if lifting it lets it all relax.
1994 L300 Jasper
1986 Scimitar 1.8Ti
dfnder
Vehicle: '91 Exceed
Post by dfnder »
I can move the 4wd stick to the various positions but wheels don't unlock when reversing
Firesong
Post by Firesong »
If you move it to 4 low does it change?
dfnder
Vehicle: '91 Exceed
Post by dfnder »
No it still stays in 4wd when I shift it to Low4, just cant seem to get the auto locks to let go. Are the caps strong enough to handle some banging?
Maybe the vibration may let them unlock...? I have tried booting it in reverse and shifting in and out of the various positions and it doesn't seem to help. I will retry the 4Low cause it was some time ago and I want to make sure it is actually going into 4Low and if it isn't then I guess it would be the linkage. I will report back after dinner! Thanks for the responses
cheers!
yojimbo
Post by yojimbo »
I would still jack a wheel up and see if its wound up.
Also, with them locked, you are not in 4wd, at least when the lever is in 2wd, its just the front axle still goes round as its driven from the wheels.
1994 L300 Jasper
1986 Scimitar 1.8Ti
Firesong
Post by Firesong »
Auto hubs can be a pain. Sounds like you may have gotten some moisture in them and they froze?
I've replaced mine with manual hubs but if yours are giving grief you should remove them, regrease them and put them back in
By all means give them a whack
You can try parking it in underground heated parking at the mall and shop for 4 hours... Then try it again
Fs
nxski
Post by nxski »
I got stuck in 4x4 once, I shifted into 2H, popped the van in reverse and got it going about 50kph, heard a loud clunk and it's been working fine ever since. I don't know if I should be recommending this but it's the only insight I have into the matter.
Try reversing in 4WD, putting it in 2WD, and driving forwards. You may also try using the brake and accelerator at the same time while doing the initial reversing while in 4WD, the extra pressure from the brakes on the hubs may help them unlock.
Locking hubs lock in both directions, you might find that will pop them loose. Sounds like they could do with a clean and re-grease, if they're not actually broken inside.
Good luck!
