left cv removal
joshh
Vehicle: 1992 mitsubishi delica starwagon
left cv removal
Post by joshh »
First off do we have to remove the whole hub/knuckle completely? Second how do I get the spline to release from inside the diff?
We have upper ball joint, outer tie rod end, and the hub cover all off. Help appreciated, thanks!!
403delica
Vehicle: LWB L400
left cv removal
Post by 403delica »
Just finished doing this a week ago to reseal the diff what I did was remove the knuckle completely then put a large worm gear clamp on the plunging inner joint so you had a place to pry out the axel... Mine was a little tough to remove but it is just a spring clip. Taking out the knuckle is easy and gives you lots of room
403delica
Vehicle: LWB L400
left cv removal
Post by 403delica »
There is a brass washer on the outer end of the cv shaft that needs to go a particular way... It has a cut in it to sit flush
joshh
Re: left cv removal
Post by joshh »
Got it. We were trying to shortcut initially by not wanting to undo the lower ball joint.
Lesson learned. Do it the long proper way, or it will take exponentially longer.
403delica
Vehicle: LWB L400
left cv removal
Post by 403delica »
Yah it pretty painless to undo those ball joints
joshh
Re: left cv removal
Post by joshh »
Well now I have more woes. After taking it for a test drive today I noticed some noise from the front diff. I decided to park and have a look underneath to see what it is. I'm leaking a thick brown oil from between the left cv and the front diff. Would this be becuase of anything from the CV replacement? or is it most likely a seal on the front diff?
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: left cv removal
Post by thedjjack »
sounds like you damaged the seal when you put the cv back in...brown thick (smells bad) sounds like gear oil
403delica
Vehicle: LWB L400
left cv removal
Post by 403delica »
Yah inner cv seal... Just did this seal on mine because a shop in Calgary butcherd it. Coombs has seals in stock and you can use the axel to drive it in
joshh
Re: left cv removal
Post by joshh »
Okay easy enough. I will order it tomorrow. So you replace the seal inside and gently use the axle to press it in the rest of the way?
Im getting sick of looking at these axles lately :-(
403delica
Vehicle: LWB L400
left cv removal
Post by 403delica »
You can or use a proper seal driver if you happen to have one... Talk to Coombs they use the old seal to start the new one it worked well but I also have a driver set
