Heavy equipment towing
sasquatch-hunter
Vehicle: 2 Delica
Post by sasquatch-hunter »
Since the L400 is doubling up at a farm truck, here is how it look when towing a post pounder. I highly not recommended and I will not do that again. The rear sunk right to the bump stop. Probably I will need some air bags or Monroe coil overloader shocks soon.
Feds
Re: Heavy equipment towing
Post by Feds »
Thanks for the inspiration, I started fabbing my hitch this evening.
jaggedfish
Post by jaggedfish »
:shock: That's some serious tongue weight!!! Dunno why they couldn't have balanced that better for towing. I have a mini excavator from Princess Auto that is beautifully balanced and a breeze to tow... even use my quad to tow it around my property. At least if you're on the bump stops you know the rear end won't go down any further unless you blow a tire... :?
rezdiver
Vehicle: 1991 L300
Post by rezdiver »
wow, I would not want to tow that with any vehicle. that looks like a very poorly designed and built trailer.
got any better pictures of it? how much does the trailer weigh with the pounder on it?
Reza
1991 Delica L300
http://www.iltisforum.com/
sasquatch-hunter
Vehicle: 2 Delica
There was a guy towed the same unit with a Suzuki Samurai in low range all the way! When the post pound weight came down onto the post, the front end of the Samurai bounded up about three feet!
sasquatch-hunter wrote:There was a guy towed the same unit with a Suzuki Samurai in low range all the way! When the post pound weight came down onto the post, the front end of the Samurai bounded up about three feet!
What some people will do for a thrill, eh?
sasquatch-hunter
Vehicle: 2 Delica
Farmer tan country here, Falco.
