Brake Fluid???
prairiefire
Vehicle: 1995 L400 Delica SWB
Brake Fluid???
Post by prairiefire »
I'm about to do my front brakes on my L400. I'm wondering how much fluid I need for a flush and bleed. Dot 3 or Dot 4?
Just want to know how much I should have on hand before I start this job.
thanks,
K
Re: Brake Fluid???
L400 Dedicated Category Reference Forum, Look for the manual and there should be a section on fluid specs... happy smiles with a rye corner of the lip.
92pajero
Vehicle: 92 pajero exceed
Re: Brake Fluid???
Post by 92pajero »
I did a flush on my Pajero a little while back and it just under a litre, around 850ml to do it. Remember atart at the furthest bleed point then work closer.
Feds
Re: Brake Fluid???
Post by Feds »
3 or 4 doesn't really matter. Just don't use 5.
It's not likely that you'll be driving hard enough to boil the brake fluid.
MardyDelica
Re: Brake Fluid???
Post by MardyDelica »
i think DOT 3 is better for origianl manufacturer application.
DOT 4 is also ok i guess but dont know what will be the outcome might have problem later with all the seal, as DOT 4 is not recommended by Mitsubishi japan for this type of car like L400.
newer year i guess they upgrade it.
Cheers;
rezdiver
Vehicle: 1991 L300
Re: Brake Fluid???
Post by rezdiver »
DOT 4 is just fine as long as it says it is compatible with DOT 3 on the container. Most DOT 3 and 4 are compatible and will not harm seals.
Reza
1991 Delica L300
http://www.iltisforum.com/
