So not sure but maybe before doing a "spin test" make sure the diff is warmed up
Joe
There is a little orange-background with yellow-text sticker on the rear door (or the door pillar of the driver's door) reminding one to use LSD-specific oil in the rear differential.RichD wrote:Hey actual experts, how does one confirm for sure regardless of which way wheels turn?
That's specific to older models. Doesn't apply to L400s. Also that doesn't mean that it hasn't been swapped out.mararmeisto wrote:There is a little orange-background with yellow-text sticker on the rear door (or the door pillar of the driver's door) reminding one to use LSD-specific oil in the rear differential.RichD wrote:Hey actual experts, how does one confirm for sure regardless of which way wheels turn?
Barring that sticker's presence (or absence), I would suggest one would have to read the description off the serial plate or the part number off the differential directly.
There are none. It is a 3rd member so you would in effect have to pull the whole thing out and see the ring gear / clutch packs.RichD wrote:I'm looking for identifying marks on the part itself, or a visual inspection one could do when changing fluids.
