Turbo and exhaust manifold gaskets
nxski
Post by nxski »
I know this is a long shot but are there any North American equivalents? It turns out that one of the bolts holding the manifold in place is missing and the gasket is leaking. Thanks
Strada 92
Vehicle: Mitsubishi Delica L400 1995
Re: Turbo and exhaust manifold gskets
Post by Strada 92 »
Not exacly the same turbo but the manifold and gasket are the same:Ford Ranger 1986-1987 2.3 turbo-diesel(4d55)
Dodge Ram 50 1983-1985 turbo-diesel 2.3(4d55)
Mitsubishi Mighty Max 1983-1985 2.3 TD (4d55)
Not really hard to find.Any good autoparts store.
Mitsubishi L400 Spacegear
Mitsubishi I-MiEV 2012
nxski
Post by nxski »
So they use the same manifold gasket but I'll still need to get the turbo gaskets shipped anyway?
I ended up getting RMI to ship me everything recently after posting this but thanks for the response. Also, I've been corrected...one of the nuts fell off of one of the studs holding the manifold in place.
At any rate, I would like to give a big thank you to RMI for being extremely helpful, well priced and easy to deal with! The parts will arrive Monday by noon, the mechanic will work on it Tuesday and i should be back on the road for Wednesday after dropping a good portion of my travel money. :-D
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: Turbo and exhaust manifold gaskets
Post by thedjjack »
Last time I had two manifolds gasket replaced on a Dodge V8 van (makes the delica look easy to work on) it cost $120.00 both sides...
Just unbolt an rebolt ...post up on http://www.expeditionportal.com/forum/ and see if anyone in the area has a shop and can help?
It is a pretty easy job and if you disconnect under the turbo you would need one less gasket...just need to pull the manifolds (intake and exhaust) off studs not remove usually (unless the gasket is really stuck).
Firesong
Post by Firesong »
If you can get away with not doing the turbo the intake and exhaust manifold
gasket is pretty easy to do. Unbolts slide away from engine, clean surface and
put new one on.. etc.
The turbo gasket usually requires the manifold and turbo to come out, unbolt
and do then replace. It takes the time
FS
nxski
Post by nxski »
I'll tell the mechanic that's what I want done then. I want to do as little work as possible on the van until I'm home and can have CVI do the work and have some income as well. On the plus side the turbo gaskets don't cost too much so I'll just have some spares.
