Part number for turn signal bulb?
Is there part numbers for the light bulbs specifically? If not does anyone know what kind of bulb i need for the front turn signal? Thanks
Re: Part number for turn signal bulb?
The front indicator lamp (lives in the same housing as the park light) is a normal P21W. Same for the rear indicator. I'm not sure what bulb goes in the side repeaters though.
yea thats the one I'm looking for. Can you pick that up at any old parts store or will i have to order it from somewhere? thanksGrowlerbearnz wrote:The front indicator lamp (lives in the same housing as the park light) is a normal P21W. Same for the rear indicator. I'm not sure what bulb goes in the side repeaters though.
I use the 1156NA. I get them From Lordco, although I'm sure you can get them from elsewhere.
- marsgal42
- Vehicle: The Mighty Gumdrop
When Gumdrop blew a bulb I took it out and looked at the bulbs at Canadian Tire until I found the right one. When you own a Delica you get out of the habit of asking the sales people for help.
If one has blown, the other can't be far behind. I always replace them in pairs. Cheap insurance.
...laura
...laura
