SOLD
SOLD
Upgrading wheels/tires.
Very light, soft polished BSA 313 16x8 alloy wheels with 4.25" backspacing (condition 9/10 - small scuffs) Centre bore 110mm (perfect for L400 large hubs)
BSA 313 : http://bsawheels.com.au/products_closeu ... art_no=534
BFG AT KO DOT tires at approx 50%. No cracking and balanced. One has an alignment wear on one side.
http://www.tirerack.com/tires/tires.jsp ... &tab=Specs
Size: 265/70/16 (31x10.5 equivalent) Load range 'D'
This would be well suited to either an L300/L400 with a 2" lift or use the wheels with smaller tires or on a stock Pajero.
16x8 BSA 313 alloys go up from $250/ea. in Europe
SOLD pickup in Vancouver or I can ship them greyhound around Canada COD (approx $70)
Jordan
Vehicle: 89 low roof L300
Re: BSA 313 - 16x8 alloy wheels on BFG AT 31's
Post by Jordan »
Hey Jesse, I am interested in the rims/tires. I am in Nelson but am going to the coast at the end of march. I have the 2" lift on my L300, will these clear the control arms and sliding door?
Jordan
Hey Jordan
These will fit on the L300 with a 2" lift.
I would have to mount it on one to check the A-arm distance from the tire. I may be able to do that this week.
They won't stick out past the body so no issue with the sliding door.
edit: the offset is close to stock and the tire 'may' be close to the control arm. In my opinion this setup 16x8 with this tire size is better suited to an L400 but I wouldn't discount them fitting snugly on an L300.
Sold to Fred.
Cheers :M
