Hey all,
I got a stupid "it sounds like KA-CHUNK" questions. Forgive me, but I just took it in and they changed all my shocks which has made the ride much better but the reason i took it in for, is still there. So maybe you guys can help me, help them. Basically when I put it in Reverse and give it some gas (especially when I back it down my mother's driveway) I hear a 'KA-CHUNk' from somewhere under the truck, then when I put it in Drive (especially up a hill) it goes 'KA-CHUNK' again. Does not sound good. Any ideas as to what the hell is going on under there? Should I take it in ASAP or can I let it ride a bit as I just spent $600?!
. . . 'it sounds like KA-CHUNK' question
- Vehicle: 92 pajero
Re: . . . 'it sounds like KA-CHUNK' question
Did they check your bushings when they replaced the shocks?
- mdrive
If you hadnt heard this noise before replacing the shock, it could be shock bushings are not properly installed. also check bushings in the control arm.
drive shaft u-joints have slop in them? they shift everytime you change their rotational direction.
have the van off and in park/gear, get under there and grab the shaft, rotate it and check for excessive slop.
x2strada-caster wrote:drive shaft u-joints have slop in them? they shift everytime you change their rotational direction.
- Vehicle: L400
Thanks all. Drive shaft U-joints - Seeing as the sun is out, I'll get under and check for 'excessive slop'.
Cheers.
Cheers.
