Bush Bar Removal?
- Pete and Jackie
Bush Bar Removal?
I know its in here somewhere. I'm trying to get the bush bar off the front of my L300 for repaint. Could I get a bit of direction please? I'm afraid to start breaking plastic. Pete
Re: Bush Bar Removal?
Six Bolts: Two "tongues" protruding from the oil rad grille, two bolts apiece; two more attach the two bottom bars to the vehicle frame. You get the fogs off by first unplugging them underneath the cowling; remove the top vinyl piece of the cowling (aka shroud); then you will have access to the four upper bolts that hold the bars on. You should remove the two lower bolts before you remove the upper ones.
Check this link out:
