Hi everyone,
I just spent 3 hours troubleshooting a non-starting van. After running through the checklist from batteries, fuses, solenoid, starter, I ended up in the ignition switch in the steering column. The group of wires on the left side of the column do not appear frayed, loose or at all compromised, but when I give the whole thing a jiggle toward the inside of the column the van starts when I turn the key.
Looking at how to get the key ignition out to have a look inside, it seems that it's all attached with breakaway bolts. I guess as an anti theft device??
Is the only way to get at this area is to pull the whole column off or should I go the way of an "easy out" to get this off.
Any advice would be great. At this point I am happy that I can at least get the van started and it is not just dead in the water (or should I say winter).
Sean
Wiring in Steering column - van did not start
- sean
- Vehicle: WVO '91 Super Exceed
"I find television very educating. Every time somebody turns on the set,I go into the other room and read a book."
Groucho Marx
Groucho Marx
Jump to
- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
