2.8 fast idle ?
Zeroduty
Vehicle: mitsubishi pajero
2.8 fast idle ?
Post by Zeroduty »
Has anyone come up with a way to rig a fast idle for winter by using the fast idle set up for the AC? Is this not controlled by an electric solenoid? If so maybe it could be over ridden some how?
Vern
lopar
Vehicle: L400 (soon)
Re: 2.8 fast idle ?
Post by lopar »
might just be the extra load of the ac compressor that bumps the rpm......... not sure
might try to come up with something this week as I am working on my injectors and doing up a glow plug mod
It's a mechanical pump, might be a challenge to do, other than the classic stick......... hmmmmm :mrgreen:
Manitoba deli
Vehicle: 94 l300, 94 l400 lwb, 97 l400 S II
Re: 2.8 fast idle ?
Post by Manitoba deli »
Bolted to the side of your intercooler are two vacum switches, one of them controls the A/C fast idle. It was the front one on mine.
Jason
Zeroduty
Re: 2.8 fast idle ?
Post by Zeroduty »
So if the switch is disconnected and I run a powered lead to it I should have a manually controlled fast idle. By the way could you pm your phone #, I think that you very likely are from my home town. I think you were on a farm north east of town.
Vern
Manitoba deli
Re: 2.8 fast idle ?
Pm sent.
The location of the vacum switch I gave is on the l400. Sorry I wasn't paying attention. If you follow the vacum line from your IP it should lead you to the right switch.
Jason
