**SOLD**For Sale: Snow Tires
shealy
Vehicle: 92 Delica Exceed
Post by shealy »
EDIT: Tires are sold!
Finally got new Geolanders on my Deli thanks to Artacoma(Rik) and they look great! I have a set of Snow Tires that were on there before that I'm trying to get rid of if anyone is interested:
Triangle "Snow Lion"
215/70R15 (98T TR777)
The sizing will fit the stock "teardrop" shape rims. I'm not sure what % tread is left, but it looks like there's about 3/4 cm deep tread left. I had these tires on snow covered logging roads earlier in the year and was totally comfortable and in control at 50-60km! I would assume at least 2 winters left in them (especially if only put on for the winter months). I'm thinking maybe $150 or any reasonable offer! Its supposed to be a cold and snowy winter! Thanks guys!
(pic that shows the tread left)
Re: For Sale: Snow Tires
Judging by the wear pattern on the outside edge of that tire and not on the inside edge, I'd say you're wheel alignment is a bit off. :shock:
That being said, 150$ for a set of four tires - that's pretty gorram good in my books! Too bad I've got a set of brand news just bought or I might have taken you up on the offer.
shealy
Post by shealy »
The alignment shouldnt have been off. It had been aligned at CVI earlier on in the year!
bassnailer
Vehicle: '92 L300 Super Duper Exceed
Post by bassnailer »
pm sent
nxski
Re:
Post by nxski »
shealy wrote:The alignment shouldnt have been off. It had been aligned at CVI earlier on in the year!
I too had mine aligned there earlier in the year and had to take it back to have them re-do it because for some reason the machine had been malfunctioning. That could be your problem!?
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: Re:
Post by thedjjack »
The question is did that wear occur prior to the alignment or after? Fixing the alignment will not put rubber back on tires :-D
Also, even aligned you need to rotate often on the Delica to get even wear of the tires.
