Help,altenator bolt sheared off
visotzky
Vehicle: 1990 P35w Crystal Lite
Post by visotzky »
I am in Penticton for the week, and the bolt holding the the altenator at the top has sheared, therefore no belt tension. Does anybody know a mechanic that can handle this in penticton. I am afraid the little bit that the tension screw goes through, is lost. the location of this problem really pisses me off, how the hell are you supposed to work onit? If i can't get the bolt out how can i get tension on the belts ? any ideas?
Val
http://www.visophotography.com
1990 Delica Crystal roof.
Re: Help,altenator bolt sheared off
It's an akward place to work on.
Without knowing where it sheared, its hard to give advice.
May have to drill it out or use a reverse thread bit to remove the sheared section. Most mechanics should have these tools.
visotzky
Post by visotzky »
It's the bolt that holds the tensioning screw. It goes from that little piece on the tensioning screw to the alternator. The piece of bolt is still in the alternator.
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
You can pull out the alternator...see if there is enough to get vise grips on it. IF NO then,
next drill out for an EZ-OUT. IF NO then,
Next drill out and thread the alternator up a bolt size (or use a bolt on the back)
much better then breaking the bolt in the block.
Good luck
Agreed.
Or if you can, use a heli-coil insert.
Fishtank
Post by Fishtank »
visotzky, give me a call on my cell, I have access to tools and a shop if needed and I have dealt with alternator problems before.
250-809-1313
Ted
thedjjack
Post by thedjjack »
Good call on the heli-coil.
yojimbo
Post by yojimbo »
The odds are the remaining bolt is pretty loose, it's just not somewhere it's easy to get to.
1994 L300 Jasper
1986 Scimitar 1.8Ti
