slight smell of coolant?
joedelica
Vehicle: 95 Exceed XR The Sapporo Can
Post by joedelica »
Hi All,
Whenever I have the fan on, even the lowest setting and any setting, I get a sweet smell of coolant.
Is this a sign of something I should be aware of? The level in my coolant bottle remains constant.
Joe
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: slight smell of coolant?
Post by thedjjack »
sounds like the heater core is getting a small leak (tiny radiator in the truck that the fan blows through).
Another sign is defrost that frost the window since it is full of moisture.
NoDelie
Vehicle: pajero exceed 1989
Post by NoDelie »
This is the begining of the end. The smell is correct. That is what I went through with my 89 pajero. The smell then the drip , the coolant level did not go down at first but over time is did very little at a time. Spent a day taking the dash out, and the heater core. When I looked at the core it turned of to be a one inch hose and a weak clamp. So I had it out so off to the rad shop get rebuilt and put back in.
Got heat. ??
Smile, your boss will wonder.
joedelica
Post by joedelica »
Thanks guys,
No moisture on window when defrosting on any setting, and yes, I do have heat.
The system seems to work fine all around, just the slight hint of coolant.
Joe
joedelica
Post by joedelica »
Is the heater core under the dash? I was unable to find any diagrams?
and the important question, should I repair it or replace it?
Thanks.
What do you have ? L300, L400 or Pajero ?
joedelica
Post by joedelica »
95 L400
DeliTan
Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=13029
Vehicle: 94 L400 LWB Crystal
Post by DeliTan »
If you have a mat over the passenger footwell carpet, check for dampness underneath
john
joedelica
Post by joedelica »
Footwell and carpets not damp or wet any where.
thedjjack
Post by thedjjack »
I suspect it is just starting to get a leak or a bad hose. New or rebuilt both are equally fine.
Not sure where exactly it is on the L400 (I own the way sexier L300 :roll:)
Look under the hood and two hoses will go from the motor to the heater which is under the dash most likely on the passenger side of the truck.
page 34 of manual from heater l400 download section everything
http://www.delica.ca/manuals/L-400%20Ma ... IR_CON.pdf
Hope that helps.
