Noob Question
Re: Noob Question
Post by Green1 »
sure enough, a factory installed high mount brake light.
these are standard on Delicas after August 1991, the catch is that you loose access to the rear lock button (it's under that brake light,
In fact, the lock button is STILL THERE! if you remove the brake light you can use it... I'm sure there is a way to rig something so that you can keep both, but I haven't yet figured out what it would be (and my incentive isn't so much, as my Delica is older than that change))
quadzilla
Vehicle: 1992 Exceed
Re: Noob Question
Post by quadzilla »
BTW - the reservoir for the rear washer fluid can be accessed through the corner panel near the floor behind the rear bench. Jack in one, reservoir in the other.
Artacoma
Vehicle: 97 V6 LWB
Re: Noob Question
Post by Artacoma »
'Nother point I took off my high mount light and drilled a 1 1/2" hole in the housing so I can now accsess the inside lock button. Before it goes back on you have to put a strip of electrical tape inside to mask the light so it doesn't illuminate the inside of the van. I'll post a pic when I get back from holidaze.
Rik
97 Series 2 V6 LWB
Re: Noob Question
Post by Green1 »
I was thinking along those lines, but it looked to me like the actual light itself would interfere... I'd be interested in seeing the pictures...
I was also thinking that a smaller hole would work with an extended lock button (visit pick-a-part and find some vehicle with taller ones) for a tidier result...
Artacoma
Vehicle: 97 V6 LWB
Re: Noob Question
Post by Artacoma »
Just went out and took some pics but my fancyass macbook pro keeps crashing safari when I try to add attachments to a post. I'll fiddle with it sometime in the next couple of days.
Rik
97 Series 2 V6 LWB
JMK
Vehicle: 92 Chamonix
Re: Noob Question
Post by JMK »
So the next question I have with regard to this. Was the switch on the dash meant to replace the fact you can't manually depress the rear gate lock?
Re: Noob Question
JMK wrote:So the next question I have with regard to this. Was the switch on the dash meant to replace the fact you can't manually depress the rear gate lock?
No, I think the switch on the dash is a hold-over from the original purpose of these vehicles "DELI"very-"CA"r. Thus, the driver stays in the vehicle and can unlock/lock the rear gate. The Moon Machine is a 1990 and doesn't have the high-mount brake light, but does have the gate switch on the dash.
Just my thoughts on that question...
JMK
Re: Noob Question
Post by JMK »
Interesting, thanks for that.
So when you use that switch, does the locking knob on the rear gate physicaly move up and down? Also I'll have to check and see if the remote that unlocks the doors unlocks the gates.
Speaking of remotes, I believe I found the one wiring diagram in the forum, L300-L300_wiring.pdf. Is that the wiring diagram that most are using is is there another one? I'm having trouble figuring out how to print a zoomed page.
Schwa
Vehicle: 1992 Delica Exceed
Re: Noob Question
Post by Schwa »
Artacoma wrote:Just went out and took some pics but my fancyass macbook pro keeps crashing safari when I try to add attachments to a post. I'll fiddle with it sometime in the next couple of days.
Try with it with Firefox, I know Safari is based on the KDE browser engine (Konqueror) and it has a few standards compliance issues.
Re: Noob Question
Post by Green1 »
Yes.
As the Delica doesn't come from the factory with a remote, it will all depend on how the person who installed it set things up. Most likely it won't as it's a completely separate circuit, however it could be wired to do so. (the remote I have for my vehicle has the "trunk release" button wired to unlock the tailgate, but I still have to lock it manually (which isn't a big deal for me as my vehicle is from before the brake light was added so I just hit the button while closing the tailgate))
JMK
Re: Noob Question
Post by JMK »
I didn't realize the remote was aftermarket, it looks ancient enough that I just assumed it was factory. They probably installed it when they did the Turbo Timer which I assumed was aftermarket.
BTW, these Turbo Timers. If you remove your key and leave the vehicle could someone still drive away while the timer is active?
Did you wire your remote yourself? If so, which wiring diagram did you use? (I've got a remote start kit I need to tackle sometime soon. )
It started today at -16 but it took a few tries for sure.
Thanks for the info.
Re: Noob Question
Post by Green1 »
not if done properly. key word being properly. any system designed to have the engine running while the vehicle is un-occupied would normally be equipped with a fail-safe of sorts, the usual one is to shut-off the engine if the brake is applied and no key has been put in the ignition, being that you need to apply the brake to shift out of park, you can't go anywhere without the key. (that's how mine works anyway)
I didn't wire in the remote myself, however the basics are that the Delica only has power locks on 2 doors (passenger and sliding) the driver's door is just the switch that controls the other locks (it remains manual) to make a full power system you put a solenoid on the driver's door lock, and then power that from the remote (running new wires to it) making the existing wiring irrelevant.
To control the tailgate from a remote you simply tap in to the wires on the back of the dash switch.
Wires for the starter can be found inside the steering column (back of the ignition lock) and a brake input can be taken from the brake switch (on the brake pedal)
JMK
Re: Noob Question
Post by JMK »
Thanks for that.
SO the remote that came with it pops the door locks up on both the passenger and driver's doors. So that must mean that whoever installed it must have also installed a selenoid. If I'm about to install another system, I guess I better look for the aftermarket system that is there already first.
Getting under the dash is certainly not an easy task with these units, maybe it would be best to remove the driver's side seat first.
JMK
Re: Noob Question
Post by JMK »
New problem I see now. The temp is about -26 right now, and the sliding door does not unlock. As it hasn't been washed since last Friday, it is not water in the lock. Is there a known problem with the lock on the side door freezing up? It also seems that the elecronic gate lock switch is not working.
Re: Noob Question
Post by Green1 »
the sliding door lock gets it's power from a pair of contacts on the forward end of the door, if these are dirty it could affect the operation of the lock.
