help..glowplugs won't work anymore!!
patty
Vehicle: delica chamonix
Re: help..glowplugs won't work anymore!!
Post by patty »
rehabilitating a super old post here but had a nube question for ya'll
so theres all this talk in this post about glow plug circuit board and all that jazz. am i wrong to assume the glow plugs themselves would be in the same place?i have no idea where the plugs are and would really like the check them. hopefully their the reason why i cant start!
after oil
Post by after oil »
patty, the glow plugs heat the combustion chamber. they are screwed right in to the cylinder. if you look at your engine, you will see a flat metal rail connecting the four plugs, and the rail is attached the the ends of the plugs with nuts. you can attach a 12v test light to them and turn the key to the on position when the engine is cold. youll likely only see 12v power for the few seconds between the "cliks" of the ecu
coaxial
Post by coaxial »
just thought I'd add that my glowplugs stopped working the other day, volt tested the plugs and relay and got nothing, pulled the ECU and it looked fine, took the circuitboard right off and it looked okay until I noticed a bit of corrosion on the leads on the bottom.
Tested them and confirmed one path was broken, bypassed it with a wire and it is all fixed! cleaned it up and sealed it all with silicone.
Took pics of the whole process, posted here http://www.flickr.com/photos/coaxial/se ... 71/detail/
deLOOKA
Vehicle: 93 SE
Post by deLOOKA »
WOW! 8-)
Thanks for the info!
Love the "approved by" smile at the end.
Lapprentis
Post by Lapprentis »
Glad to know it can be the ECU. Now, in my case, First Clic OK but NO Second Clic. So, tight the Battery Poles, in my case, bolts over the + Positive pole and the pole itself. Turn out to be enough :)
Lapprentis
