Ian will be working his magic on it fixing the damage I did with the sos pads. First time we met in person and it turns out we've met about 25 years ago. Small world !
Removing road tar from vehicle
Re: Removing road tar from vehicle
it's the sun and heat that baked it on in the first place. I tried the acetone on a small corner patch along with all the others on the list above no no avail.
Luisito
- Member's Photo Album: http://virilesoulcreations.weebly.com/moon-unit.ht
- Vehicle: L300 High Roof
I just caught this... was going to suggest acetone but it sounds like you've tried that already. Mineral spirits would be my next suggestion. I asked someone here at work and they suggested laying on peanut butter, letting it sit for half an hour, and then scraping off - wasn't sure if that was a joke or not, they seemed pretty serious! Good luck with it, let us know how it turns out.
I heard what was said about the Forum community... my sense of it being a newcomer is that it is pretty cool, but perhaps it was even better in days of yore. :)
I just got a tip from a guy who was polishing his car that a wet ' Bounce ' sheet works well. I haven't tried it yet but if it works they are cheap and easy to find.
everything what has been mentioned would have probably worked on dirt, sap, soft tar, etc... but these little bits of tar felt like jagged diamonds and were hard as rock embedded into the clear coat.
Luisito
Aw man, that's a real drag Jesse... wish we could help more. Good luck.
madmazda
- Vehicle: 1994 l400
Have you tried " GOOF OFF" canadian tire sells it....
That stuff is amazing! It took of the stickers that had been on my ski box for 30+ years with ease when lacquer thinner, wax remover and paint thinner couldn't even make a dent.madmazda wrote:Have you tried " GOOF OFF" canadian tire sells it....
Now would be a good time to RhinoCoat the lower portions of your ride - then the tar flicked up from the road wouldn't even be noticeable.
Goof Off is comprised of toluene and xylene. Lacquer thinner has that and more, like keytones, acetone, methynol ~ really good for removing paint ~ for that matter so is Goof Off. Goof Off is sold in paint trade stores for removing paint that has gone onto something it shouldn't have. Goof Off is expensive because it is a brand name. Lacquer thinner will equally or better destroy your paint job than Goof Off ~ for far less money.madmazda wrote:Have you tried " GOOF OFF" canadian tire sells it....
Copy thatmararmeisto wrote:Now would be a good time to RhinoCoat the lower portions of your ride - then the tar flicked up from the road wouldn't even be noticeable.
Ian (Aciled) contacted me and offered his help to restore the paint on our rig.
I've never met him before and it was the classic 'Delica-owner-help-out-another-Delica-owner' which is why this community works so well.
He did an amazing job restoring (more like fixing my sos pad scruffing) the paint. Looks to beautiful to take off the pavement now.
Thanks bro
Before pictures (after the SOS pad scruffing - it was bad - like a flat dull paint)
Thanks bro
- photo1.jpg (107.87 KiB) Viewed 4720 times
- photo2.jpg (112.44 KiB) Viewed 4720 times
- photo3.jpg (112.25 KiB) Viewed 4720 times
After pics
- photo4.jpg (146.61 KiB) Viewed 4720 times
- photo5.jpg (177.5 KiB) Viewed 4720 times
psilosin
- Vehicle: L400
That is quite an impressive transformation.
Thumbs up.
- Aciled
- Vehicle: 94 L400 SE SWB
Your welcome 'young fella', its been a while since I cut a "BLACKY"
Lets keep it that way...
" GOOF OFF"
'I like that name, maybe I'll consider changing my member's name to it... although SOME people might think I mean the "F" word..lol
" GOOF OFF"
I do like how the flared fenders on the Safari are part of the body and not just snapped-on-plastic bits (like on my Pajero). When I go and spend a bucket-load of money on a paint job, maybe I have something like that fab'd up - then my Paj would really rock!
And I get some flash rims.
And low profile tires.
Tint ALL the windows.
Remove most of the suspension and slammed that mutha down!
Okay, I may have got a bit carried away there...
