Need a new ecu I think
irish_delica83
- Vehicle: 92 delica exceed
gonna go get muudy after fresh wax
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Re: Need a new ecu I think
thedjjack wrote:I was going to put a Mercedes controller in mine when it goes (you can get them new for around $100-175).
It has a temperature input and runs the plugs for up to 3 minutes after it is started. It has a 80 amp fuse built in and serves as the relays as well. Simple and well built.
here is the manual for one: http://handbook.w116.org/Engine/617/15-705.pdf
just an idea
Replace the 6volt with 12 volts get a used Mercedes Controller (lots of old Mercedes being wrecked on Craigslist). wire it up and let us know how it works out!
- marsgal42
- Vehicle: The Mighty Gumdrop
What makes you think you need a new one? The usual failure mode (no activity) is caused by dead capacitors, and is easy to fix.
...laura
...laura
- ccautos
- Vehicle: 92 Delica SE
These units can be easily rebuilt by any competent electrical repair facility. We have them reconditioned and tested on the shelf $150 (exchange). Can be cheaper if you have the time to take it in and wait for the repair.
Yokohama
Sounds like the DSM and other Mitsubishi ECU failures due to the leaky electrolytic capacitors. Most of the time in the DSM units it is the larger "can type" capacitors and not the surface mount units. The can type are easy because the values are printed on the sides, but the small surface mounts would have to be tested to determine the values if you did not have a schematic diagram.marsgal42 wrote:What makes you think you need a new one? The usual failure mode (no activity) is caused by dead capacitors, and is easy to fix.
...laura
I should start offering a repair service for ECU's. I also like to install a socket for the EPROM in a ECU as then you can replace it easily, or use one of the ROM interface systems on the market.
This happened to my L300 ECU, but almost every capacitor of both types was leaking! So it was just easier to just grab an ECU from a 1990 Mighty Max (the only year that had the same system and high-impedance injectors like the 88/89 USA L300). The ECU is a California ECU and my L300 is a federal system, so I do not have EGR! Hence, the ECU generates a code 64 (EGR temp sensor code) and the check engine light comes on. I plan to trick the ECU into "thinking" that the sensor is there.
You should get a portable oscilloscope since you have an OBD-I system; you can just time scale and read the number of square-wave pulses as opposed to counting light flashes or volt meter needle deflections.
I am thinking about doing a stand-alone system however (i.e. MegaSquirt 3).
irish_delica83
Install a switch to the relay today yeah!! No more smoke show
Is it a momentary switch that disengages when you let it go? Would be best, otherwise you'll burn out your glowplugs when you forget to turn the switch off that one time. Just a thought.irish_delica83 wrote:Install a switch to the relay today yeah!! No more smoke show
Good to hear you got it fixed, just the same.
- Lapprentis
A general ECU question: are the L300 ECU interchangable ? MD172612 (1992) / MD119332 (1990) ?
Lapprentis
Lapprentis
