Horn issues
delidemon
Vehicle: L400 SWB Gasser!!!
Horn issues
Post by delidemon »
So I picked up my new Delica and I am getting it ready for the OOP and I can't seem to get the horn to work. Tried swapping the fuses with no luck and now I am trying to find the wiring issues.
Anyone with experience or ideas?
Thanks,
Don
busrida
Vehicle: 94 L400
Re: Horn issues
Post by busrida »
Mine died on me just the other day. The fuse is fine so I'm assuming the actualhorn either got wet in the snow or just died. Either way I picked up an air horn tonight so if it's wiring I'll let you know after the weekend.
Re: Horn issues
Have you checked the connexion in the steering wheel?
Golf Cart
Vehicle: 1992 Exceed
Re: Horn issues
Post by Golf Cart »
Pop the leads off the horn itself and see if you are getting juice to it. If not then I would check the connection at the steering wheel.
delidemon
Post by delidemon »
Thanks for the ideas. That will be today's plan.
busrida
Vehicle: 94 L400
Re: Horn issues
Post by busrida »
Not to hijack your thread... But I figured we could share your horn thread. ;)
Replaced the interior fuse this evening, hit the horn and it worked. When I tried it again it was dead with another blown fuse. I assume (correct where necessary) this would indicate a short somewhere between the steering wheel and the interior fusebox. What colours are the horn wires? I'd really like to get this cleared up tomorrow.
Thanks.
nxski
Re: Horn issues
Post by nxski »
What was the result of this? Is it a stock steering wheel? I had a problem getting mine to work with my new steering wheel as there was no connection point for the ground wire. I ended up taping the ground wire to the interior or the hub adaptor and problem solved.
Return to “L400 Technical”
