Mitsibushi Delica Van (Diesel) 4D56 1990 wiring diagram
antigraviddy
Vehicle: Delica Exceed (4D56)
Post by antigraviddy »
Can anyone help with a fuse box diagram for the abovementioned VAN?
Thanks in advance :-)
is it this one http://i78.photobucket.com/albums/j86/b ... seBox2.jpg
or this one
http://www.delica.ca/forum/l300-main-fu ... s-306.html
Re: Mitsibushi Delica Van (Diesel) 4D56 1990 wiring diagram
Yes, there is a forum on this site called "Delica Canada Technical". In that forum is a sub-forum called "L300 Delica Downloads". Get to know this website and you will discover marvels... smiles.
Since this is a technical question I've moved it to "L300 Technical".
antigraviddy
I posted the question because i found conflicting diagrams
Super Exceeded
Vehicle: 1993 L300S
Post by Super Exceeded »
I feel your pain. Right now I am using two wiring harness from two different L300's and Mitsubishi was good enough to use different colour wires in each harness. This has made duplicating very difficult.
after oil
Post by after oil »
when in doubt always trust mystery machine!
heres one you can DL and print for your box...
Uploaded with ImageShack.us
antigraviddy
Thanks for that.
so no specific fuse slot for glow plugs then?
On this page in the L300 Delica Downloads forum are five manuals or schematics. Regarding the glow plugs I would recommend "Engine Electrical Manual". This is the shop manual published by the Mitsubishi Motor Corporation. In the margin of the PDF file is a sub-heading "Glow System", try that.
Electrical Wiring Diagrams & Manual for the L-300
Golf Cart
Vehicle: 1992 Exceed
Post by Golf Cart »
Antigraviddy,
Might be an idea to post your geographical location on your profile. That way, one of the many members can offer up a drive by to help you out.
K Guys ....................you know your our there !!!
antigraviddy
Golf Cart wrote:Antigraviddy,
Any one in Taranaki, New Zealand? :-D
Thanks for all your help people. I think through process of elimination I have discovered that it is the Glow Plug Relay system. Now i just need the part numbers :roll:
There's a guy called Dave in Auckland, New Zealand with a sky blue over white '90 L300 Exceed. He's a structural engineer and here is a link to one of his threads which may help you out a wee bit:
Pommie In NZ!
This is why it is a good idea to post your general location in your profile... smiles.
P.S.: Regarding the part numbers ~ Check out Delica FAQs forum or L300 Delica Downloads forum; the latter will lead you to OEM numbers rather than Canadian numbers.
antigraviddy
Hey all
Thanks for information, i am slowly getting there. Can anyone tell me where the Glowplug controller is located? Thanks again.
I typed "glowplug controller" into the search engine (in the upper right part of this page) and this is one of the links that I found: help..glowplugs won't work anymore!!
Have a butcher's... smiles.
