mitsubishi relays
- Vehicle: delica
mitsubishi relays
where are the relays located in the Mitsubishi as our indicators are not working”
- loki
Re: mitsubishi relays
anushamanne wrote:where are the relays located in the Mitsubishi as our indicators are not working”
what type of delica? L300 or L400?, in the L300 I believe they are behind the glove box, not sur eon the L400.
L300 above fuse panel on drivers side bolted to the right inner panel facing in to the vehicle.
L400 under drivers side dash panel in fuse box and in the under hood fuse panel on right side of engine bay.
Try turning the hazard light switch on and off again as if the switch is not full off then turn signals will not work.
Hope this helps.
Hope this helps.
- loki
Pacific JDM Parts wrote:L300 above fuse panel on drivers side bolted to the right inner panel facing in to the vehicle.
Hope this helps.
that's the fuse panels, I don't think the flasher "relay" is in the same position.
Actually, if the L400 is like my GenII Pajero, the relays are in the fuse panel. All together, nice and tidy.loki wrote:that's the fuse panels, I don't think the flasher "relay" is in the same position.
@anushamanne Depending on what year your L300 is, your flasher relay is going to be on the driver's side where Pacific JDM Parts indicated or it's going to be on the passenger's side behind the glove box.
- loki
mararmeisto wrote:Actually, if the L400 is like my GenII Pajero, the relays are in the fuse panel. All together, nice and tidy.loki wrote:that's the fuse panels, I don't think the flasher "relay" is in the same position.
ah so we where both right.... and both wrong lol
- Jsq
- Vehicle: 91 L300 High Top
Are these the culprits you are talking about?
- relays.jpg (54.05 KiB) Viewed 9430 times
- speaker removed.jpg (70.57 KiB) Viewed 9428 times
- view behind speaker.jpg (45.92 KiB) Viewed 9428 times
- Behind dash on RH side.jpg (85.76 KiB) Viewed 9427 times
- Golf Cart
- Vehicle: 1992 Exceed
NopeJsq wrote:Are these the culprits you are talking about?
- Jsq
What purpose do those four relays serve? Never took the time to investigate. Just snapped shots of everything before putting the dash back together.
- Golf Cart
Those relays operate the power windows, heater motors rear, rear wiper/washer, and the emergency flashers.Jsq wrote:What purpose do those four relays serve? Never took the time to investigate. Just snapped shots of everything before putting the dash back together.
The Turn signal flasher is in behind the glove box just left of the end of the wiper motor. Its black and sitting bolted up on the dash frame. A bytch of a spot. Hope the pic helps
- IMG_2859.JPG (399.7 KiB) Viewed 9335 times
- Jsq
Thanks GC! While we are in the "neighbourhood" do you happen to know off hand what this timer is for?
- time relay.jpg (70.09 KiB) Viewed 9322 times
- Golf Cart
Off hand, not a clue. But in a previous discussion, somebody mentioned something about the A/C
when I asked about that timer in the past I was told it was related to the cool-box (and hence the A/C system) (if you don't have a cool-box, then I guess it's just the A/C)
Unfortunately nobody has ever managed to find a wiring diagram or service manual that covers the climate control system in the L300
- Jsq
Ok thank you. I guess it's time for a little electrical investigation. I'll see if I can trace it out before I run out of patience. LOL
- Golf Cart
Sorry Jsq. I dont have a part number for patience, nor any to spare when it comes to wiring
Good Luck and post your findings
