running weird
deli1733
Vehicle: 1991 L-300 94 Pajero LWB
running weird
Post by deli1733 »
my van has started to run worse and worse... it has a shudder when taking off and when changing gears, only noticeable from 1st to second tho. my fuel economy has gotten pretty bad about 400- 450 per tank and it tends to be getting hotter faster... hits about 2 3rds the way up the meter, i have no idea how hot that is so its kind of useless. starts in the morning are getting worse as well, even starting to stall once or twice and runs rough for about 30 seconds and its not that cold out. any ideas???
Re: running weird
When did you last change the oil?
snelson
Vehicle: 92 Delica Exceed
Re: running weird
Post by snelson »
Hey 1733
First things I would be checking are:
Coolant level
Coolant colour
Oil Level
Oil Colour - any foamy-ness
How does the exhaust smell/look? Is it sweet smelling?
All these things may indicate a head gasket issue, though that's sorta rare.
Check tightness of glow plugs and injectors re. possible compression loss.
After that, I'd be taking it somewhere for a professional opinion
Could also just be a slipped timing belt.
Hope everything works out for you.
deli1733
Re: running weird
Post by deli1733 »
i changed the oil about 500 kms ago along with air and fuel filter and it was doing it before that. ive ruled out head gasket ill look at the injectors and glow plugs. but after that im taking it to cc autos cause im out of ideas. thanks.
thedjjack
Vehicle: 1989 L300 HITOP!!
Re: running weird
Post by thedjjack »
sounds like an air leak in the fuel system.
