And not this kind of photographic evidence.....Look carefully at the shadow of the car
One of our members trying to trick us with photoshop..
Interesting about having the running lights on during the day. That is a good safety initiative. They should institute that here. Especially for motor bikes.The lights do have a normal "on" setting which forces them to stay on in daylight as well as an auto setting which detects if they need to be on or not. The CD stacker should be under the front seat. There should also be a draw under the front passenger seat. Very handy to store stuff in. The compass will probably need to be reset. Just find a roundabout and as you enter the roundabout, press and hold the "set" button as you do a couple of loops and it will find it's bearings. It will need this done whenever you disconnect the battery. There will be lots of buttons to play with . Cheers..
