Thankfully, Mitsubishi Knew Idiots Would be Driving the Deli
The Pinkfingers
Vehicle: '94 Exceed
Post by The Pinkfingers »
Like me.
Going down a hill yesterday, and was gearing down near the bottom (the Jammy Dodger is an automatic, but I still like to gear down and save my brakes). Had a brain cramp and rather than click two down into 1, I clicked two up into Reverse. I was going about 30 km/h at the time.
What happened? Nothing! It was in reverse for less than a second. It began to slow down, but there was no crunching, no awful noise, no transmission left lying in the road behind me. I put it in the proper gear and drove on as normal, pretending I was cool and nothing happened.
Re: Thankfully, Mitsubishi Knew Idiots Would be Driving the Deli
ILMAO! You know.... I did that not long ago! I think that the most damage done was my self esteem got a little bent up :oops: ~ but the tranny seems to have survived. Thank heavens for the reverse beeper!
You can actually put yours in reverse while going forward ?
I can't even if I put all of my weight on the shifter (my prev auto's and in the auto Pajero/Montero's I've had)
You're not supposed to ! :o
The Pinkfingers
Vehicle: '94 Exceed
jfarsang wrote:You can actually put yours in reverse while going forward ?
I wonder if it has to do with the brake. Can you put in in reverse when your foot is not on the brake? I was braking as I did it - maybe if the brake is applied, it unlocks the reverse.
The Pinkfingers wrote:I wonder if it has to do with the brake. Can you put in in reverse when your foot is not on the brake? I was braking as I did it - maybe if the brake is applied, it unlocks the reverse.
Try it in your driveway: in neutral, try to shift into reverse without applying the brake.
The brake relay is to allow you to shift out of Park. I don't know if it is also used to shift into reverse. Will try this myself, later. At a dead-stop, not rolling along at 30km/h.
josh
Vehicle: L300 poptop gasser
Post by josh »
So I decided to be the guinea pig and brought my little van up to 100km and slammed it into reverse just to.... oh wait. no... that was a nightmare from the other night. whew. :-D anyhow, i am off to a warmer climate... catching my flight to nicaragua. see ya.
Josh
jrman
Post by jrman »
Cool....take a pic of the Parliament buildings in Managua if you get a chance....was told they look like our Provincial Capital building in Victoria with but a big gaping hole where the dome should be caused by a bomb blast! My buddy drove from Vancouver to Costa Rica at the height of the Iran Contra crap...he should have wrote a book....
Sean in North Van
1991 Delica Exceed - Scoobus
Profister
Post by Profister »
Putting your vehicle on reverse while driving should not cause any damage to an AT no matter what: otherwise there is a design flaw. I did it on my Suzuki SX4 and guess what? The engine just shut off and I was still going in silence, then put it on N, turned the ignition key to start the engine, put it on D and kept driving.
loki
Post by loki »
I was able to throw it in reverse once and actually had the tires spinning in reverse as I went forwards, I cheated though, it was a back road in farmland in Ontario that was ll ice, I first locked up the tires and then shifted into reverse and then hit the gas, rental cars are fun when your 19. :? :o :shock:
Carstairs
Vehicle: Delica L400
Post by Carstairs »
There is a similar thread on the MDOCUK site.
I think most of us have done that.
You only ever do it once.
DelicaMark
Vehicle: L400
Post by DelicaMark »
Yep! I was running low on fuel and decided to coast in neutral down the north side of the Malahat and when I put it back into "drive" I went the wrong way...I was a little sleepy after a days work. The beeper went off before it actually went into gear, but I had about a millisecond of a grinding sound. Those teeth were too long anyway :-D .
loki
Post by loki »
I avoid shifting into reverse by not pressing the button when move the shifter up, it will move all the way to N but not past unless you use the button, it will also slid back into D from N with out the button. This has been the case in all cars I have driven, it is that way (I was taught) so you can throw it into N when you lose traction in snowy/icy conditions, this gives you the best chance of your tires regaining some traction and you should hopefully be able to at least steer again :)
Chewy
Vehicle: 1995 Suzuki Every VW
Post by Chewy »
loki beat me to it. don't press teh button, just slap the stick upwards and you'll hit neutral, and then the OD button for geardowns, which I find aides in slowing the vehicle so well that I never actually "shift" on pavement.
Golf Cart
Vehicle: 1992 Exceed
Post by Golf Cart »
loki wrote: rental cars are fun when your 19. :? :o :shock:
We were poor, we couldnt afford to rent....... we just borrowed :-P
